Results 1 to 24 of 24
Thread: Using W25Q256 on Audio shield
    Senior Member Sandro's Avatar
    Nov 2016
    Rimini - Italy
    101
    Hi all, I'm experimenting a W25Q256FV 16-pin SOIC 300-mil on Audio shield Rev B (on teensy 3.6, clock 240MHz), in order to store audio files to be played. Actually I have connected the flash chip with short wires:
    In write operation I never experimented issues, while reading I've (really NOT frequent) problems (reading errors maybe?): anyone can help me to go a bit deeper and maybe understand what is wrong? Maybe I could try adding a decupling capacitor between Vcc and GND pins close to the chip...
    I have also designed an adaptor:
    but... before making it I'd like to hear some opinion/tip.
    Thanks a lot for any idea!
    3,449
    Cool
    I've tried before and I didn't get anywhere. I tried the Teensy 3.6 and it did not work. I also tried the Teensy 4.0 using the beta audio adapter that allows a T4 to use revision A/B/C audio shields with no luck. Here is the thread:
    Now, when I put the version B of the audio shield on the Teensy 3.6, I could install the 3.6 Teensy Transfer for the Audio Shield, and it could access the files (T4 right now can't use Teensy Transfer because it doesn't have the RAW HID USB support):
    But as I said in the thread, using SerialFlash did not work (I have used SerialFlash when I had it hooked up outside of the audio shield).
    I haven't gotten too far into trying various things. I do have some ideas. Some come from the Better SPI bus design paper:
    Here are some of the things I've thought about:
    • I wonder whether changing the SCLK and MOSI pins on the 3.x shields affects SerialFlash. I've tried different orderings of setting the MOSI/SCLK and initializing the SPI bus to no avail. At some point, I plan to solder a memory chip to a revision D audio shield to see if that works;
    • I want to add pull-up resistors to both pins 6 (flash memory) and 10 (sd card) to see if that helps. Possibly also hard-wiring pin 10 to 3.3v;
    • I just got in some chips for tri-stating, but I don't have a breakout setup like you do (yet). However, if it does need to have a tri-state setup, that kind of ruins using it on the audio board;
    • With other SPI devices, I have had to play with the SPI clock speed and processor bus speed. However, as I've said, I think I've been able to use the chip outside of the audio shield, so it seems something the audio shield may be doing. However, as I re-read the thread, I see I had problems when the 3.2 speed was faster than 96Mhz, so you might try setting the 3.6 speed down to 24Mhz to see if it works.
    I bought this SOIC-8 to DIP adapter made by Sparkfun. I bought the adapter and the flash memory at , and sold by digi-key:
    The chips I just got from digi-key to do the tri-state tests are:
    Nov 2016
    Rimini - Italy
    101
    Hi Michael, thank you for your answer; I didn't get if you are talking about W25Q256 32M 16-pin chip or about the W25Q128 16M 8-pin chip (which is not my case); I'm using SerialFlash in my code.
    Maybe I'm too optimistic, but I belive that there is only some simple electric issues (signal reflections... interferences) because the chip works better by shortening the wires: in a first assembly I had connected the chip using 20mm wires and the result was quite bad; now, with 8-10mm wires the behave is much better.
    Since my first post I've added a 100nF capacitor between Vcc and GND and now, after reading the page "Better SPI bus design paper" you suggested, also removed the SD card from the socket on audio board to avoid any possible interference on SPI bus... Let's see, tomorow I'll continue. I'll also test a lower clock speed, even if my application requires 240MHz to offer full performance.
    3,449
    Quote Originally Posted by Sandro View Post
    I have the W25Q128JVSIQ (128 megabits, 16 megabytes), but I suspect there may be similar issues with other flash memory chips. But if you are soldering the chip on the audio board, you have to use an 8-pin chip.
    Note, I am a software guy, not a hardware guy. So it might be something else completely. I am just guessing at the causes.
    If you aren't soldering the board directly onto the audio shield, it may make sense to put it on its own board. That would eliminate issues caused by the audio shield.
    I do wonder whether the 3.6 built-in micro SD card would be competitive with the flash memory. On the 3.6, it uses its own SPI bus, so you don't have interference with other devices on the SPI bus. It uses quad SPI instead of the 1 bit SPI used by either the audio shield SD card or flash memory connection. In my case, the primary Teensy I'm using is the Teensy 4.0, and it is harder to access the pins for the micro SD card reader underneath the Teensy. And with a micro SD card, you can go to 32GB or so in terms of memory. When the audio shield was designed, we only had 1 bit SPI external micro SD card readers.
    Looking at the schematic for the audio adapter (which I hadn't before now), I see there is a 10k pull-up resistor between 3.3v and each of the 6 and 10 pins, so in theory, you should not need an additional pull-up resistor. Pins 7 (hold in single SPI or IO3 in quad SPI) and 3 (WP in single SPI or IO2 in quad SPI) of the memory chip are wired to 3.3v, so you are pretty much limited to single SPI.
    Similarly, for the micro SD card, 2 of the pins (DAT1, DAT2) are not connected.
    And yeah, I probably forgot to take out the SD card when I was doing the initial tests.
    Nov 2016
    Rimini - Italy
    101
    This is so important to me! I didn't know this fact of quad SPI... Maybe it means that reading data rate from micro SD card on Teensy is comparable/faster than from flash memory soldered on Audio shield.. I'll try very soon to switch my code from flash memory chip to Teensy/local micro SD card, and compare both.
    Yes this is a great plus of micro SD... much more memory than I need by the way but... it's not a disadvantage!
    3,449
    Be sure to use a fast SD-HC card for your tests. Also format the card just before doing the test so the filesystem is not fragmented.
    I'm not sure whether the software or hardware support SD-XC cards (i.e. >= 64GB) and the exFat file system used for 64GB and greater..
    Another advantage of micro SD cards is you can take them off of the Teensy and read them directly on your computer.
    But if you were still wanting to do flash, FrankB posted a 'parallel SPI flash' library. I have not used it (and in fact had forgotten about it until this thread started and I noticed a reference to it). You won't be able to use the audio card, since that does not hook up the extra pins:
    Nov 2016
    Rimini - Italy
    101
    Good suggestion! I had not considered this!
    For my application, the midi expander:
    https://forum.pjrc.com/threads/57897-queued-Lilla
    100M for file system is more than enough!!
    Could also be interesting if I coud "replace" the Audio shield codec with an SPDIF output but, as long as I have experimented, SPDIF cannot replce the Audio shield: I experiment bad audio "clicks" with SPDIF, with the intense audio activity of my application; also should be checked if 'parallel SPI flash' library is compatible with SPDIF. Besides, I need stereo and 16bit accuracy (no way for PCM output, I belive).
    Let's see: in my library I'm replacing all flash reading procedures with SD procedures ... next, after the necessary debugging, I'll be ready to do some tests
    Thank you Michael!
    Nov 2016
    Rimini - Italy
    101
    But... I found this post:
    https://forum.pjrc.com/threads/55662...ight=playSDraw
    It says that for polyphonic application (mine uses 8 voices at least) it's raccomanded flash chip, not SD card... maybe I should abandon the idea of switching my project to SD ... an go on with making an adaptor for W25Q256FV.
    3,449
    Cool
    Note, the original post is about the Teensy 3.2 and the audio shield SD card.
    I suspect that with either the built-in SD card or flash memory using SPI quad that it would be much faster. Ultimately, both are just flash memory ports that can transfer up to 4 bits at a time. A micro SD card is just a flash memory chip with the pins brought out.
    It ultimately will likely depend on several things:
    • The exact speed of the micro SD card or the flash memory;
    • Whether you have to slow down the SPI bus for the card/flash memory;
    • Whether you have to slow down the processor speed because the Teensy is running too fast;
    • Whether or not the driver works with interrupts enabled, or it disables interrupts while dealing with the flash;
    • If there are other things on the SPI bus;
    • Caching behavior of the Teensy 4.0 (which in turn depends on which memory bank you are using and whether you have to flush the cache); (or)
    • If you have hardware SPI optimization enabled (this is different between the Teensy 3.6 and 4.0).
    Of course the only way to know for certain is to try it.
    Nov 2016
    Rimini - Italy
    101
    Hi Michael,
    I had not notice that!
    So.. thank you for your detailed analysis: at the moment I would remain on Teensy 3.6, or maybe switch to T4.0 in a next release; and for all the topics you point out I have no answers... I can only try to modify my code and see what happend using the SD card on my Teensy 3.6.... Even if it seems that I've reached a good point with the 32MB chip: with this cabling
    Attachment 18351
    (really not so nice to see!!) my device is working good: not any clicks or other problems after 1 hr of sound tests. This seems to confirm that in the previous arrangement there were electric problems.
    About switching my code from flash memory to SD, I unfortunately don't understand how play_SD_raw works... So this change will take long time. Don't even know what help to ask, because my library is too long and I don't want to annoy anyone. In a nutshell, I started with some trivial Ctrl-C / Ctrl-V from play_SD_raw, replacing this code:
        rawfile = SerialFlash.open(filename);
        AudioStartUsingSPI();
        if(!rawfile)
            AudioStopUsingSPI();
    with this:
    #if defined(HAS_KINETIS_SDHC)
        if (!(SIM_SCGC3 & SIM_SCGC3_SDHC))
        #else
            Serial.println("failed!");
        __disable_irq();
        rawfile = SD.open(filename);
        __enable_irq();
        if (!rawfile)
            //Serial.println("unable to open file");
            #else
            return false;
    Is it a good start-point?
    Nov 2016
    Rimini - Italy
    101
    Lightbulb
    Sorry, here:
    #else
    Serial.println("failed!") is a refuse.
    Ok, in order to understand something about playSDraw, first I'll look for the meaning of these values:
    HAS_KINETIS_SDHC
    SIM_SCGC3
    SIM_SCGC3_SDHC
    Nov 2016
    Rimini - Italy
    101
    The attached pic was this:
    In these day I went on with my tests... and this assembly showed some limit: with intense use of the chip some errors appares. I guess if a small PCB with its groun plane could help data transmission. In the meanwhile I'm trying to switch my code to playSDraw.
    Nov 2016
    Rimini - Italy
    101
    Hi Michael,
    I made some tests with micro SD built on Teensy 3.6, clock 180 MHz; I played with play_SD_raw, modifying the lenght of the data array read from SD, as follows.
    The "core" part of play_SD_raw.cpp, a bit modified in order to change the number of samples read from SD, is:
    if (rawfile.available())
            blocks ++;
            t = micros();
            rawfile.seek(x); //  uint32_t x is declared as private in the header .h
            n = rawfile.read(basket, AUDIO_BLOCK_SAMPLES * 2); // int16_t basket[1000] is declared inside update()
            for (i=n/2; i < AUDIO_BLOCK_SAMPLES; i++)
                basket[i] = 0;
            x += AUDIO_BLOCK_SAMPLES * 2;
            for(uint16_t i =0; i < AUDIO_BLOCK_SAMPLES; i++)
                block->data[i] = basket [i];
            transmit(block);
            if (!(blocks % 200))
                Serial.println(micros() - t);
    Using the code above, the lap time micros() - t is 8-9 microseconds and this is a very, very good value!
    But, if I change a bit the number of samples read, from (AUDIO_BLOCK_SAMPLES * 2) to (AUDIO_BLOCK_SAMPLES * 4):
            blocks ++;
            t = micros();
            n = rawfile.read(basket, AUDIO_BLOCK_SAMPLES * 4); // int16_t basket[1000] is declared inside update()
                basket[i] = 0;
            transmit(block);
    than micros() - t rises up to 552-644 microseconds...
    Do you know what happens? why this huge fall of performance?
    Thank you
    3,449
    Thank you
    No idea. You would need somebody who has more experience in SD cards and the libraries involved.
    21,071
    Only 9 us is a suspiciously low time for a SD card sector read. Are sure you're really capturing a representative sample of the actual times? Would be much better to compute the min, average and max times and print those 3 numbers. As I understand this code, it seems you're printing only a single measurement every 200th run and ignoring everything that happens in the other 199 cases. A min/avg/max report covering all 200 would show a clearer picture of what's really happening.
    On the slow performance, it the SD card has to fetch another sector, and especially if a FAT sector needs to be read as well as a data sector, you can expect the operation to take some time.
    One thing you might try if you're using the SD card by SPI (not the builtin SD socket on Teensy 3.6) is the experimental SD optimizations. Edit SD_t3.h to enable that code. It caches several sectors. But it was written before Teensy 3.6 and 4.0, so it only supports SPI access to the card. It's also read-only, which is most of the reason it's considered experimental. But it's really useful to compare against the default SD library code if you're seeing performance issues.
    Nov 2016
    Rimini - Italy
    101
    Hi Paul, thank you for your answer; I started adding some lines in order to get min, max and average times, and the result was so strange (for me!), that I decided to see each value; this is my code, normal speed playback:
    void AudioPlaySdRawMod::update(void)
            t = micros();
            rawfile.seek(x);
            for (i = n/2; i < AUDIO_BLOCK_SAMPLES; i++)
                basket[i] = 0;
            x += AUDIO_BLOCK_SAMPLES * 2; // uint32_t x, defined in header
            for(i = 0; i < AUDIO_BLOCK_SAMPLES; i++)
            t_array[blocks] = micros() - t; // uint16_t t_array[256], defined in header
            transmit(block);
            blocks ++; // uint32_t blocks, defined in header
            if (blocks == 1000)
                for(i = 0; i < 1000; i++)
                        Serial.print(i);
                        Serial.print("  ");
                        Serial.println(t_array[i]);
                blocks = 0;
            rawfile.close();
            playing = false;
        release(block);
    and this is the result:
    1  7
    2  210
    3  7
    4  212
    5  7
    6  212
    7  8
    8  212
    9  7
    10  212
    11  7
    12  211
    13  7
    14  211
    15  7
    16  213
    17  7
    18  213
    19  8
    20  2138
    21  7
    22  212
    23  7
    24  211
    25  8
    26  211
    27  8
    28  213
    29  7
    30  213
    ... and so on
    Using the following code (playback at double speed):
            t = micros();
            rawfile.seek(x);
                basket[i] = 0;
            x += AUDIO_BLOCK_SAMPLES * 4; // uint32_t x, defined in header
                block->data[i] = basket [2 * i];
            transmit(block);
            if (blocks == 1000)
                        Serial.print(i);
                        Serial.print("  ");
                blocks = 0;
            rawfile.close();
            playing = false;
        release(block);
    the output is more uniform:
    1  211
    2  211
    3  212
    4  211
    5  211
    6  211
    7  211
    8  211
    9  214
    10  210
    11  213
    12  213
    13  212
    14  213
    15  213
    16  212
    17  213
    18  213
    19  212
    20  212
    21  211
    22  210
    23  213
    24  213
    25  212
    26  212
    27  213
    28  216
    29  213
    30  213
    ... and so on
    All these tests have been done with a Sandisk ultra 32GB not recently formatted: tomorrow I'll do a deep format and will repeat all tests.
    About trying SD_t3.h I belive this a bit too difficult for me; at this point I think I'll make a small PCB with a ground-plane for W25Q256, to be mounted on the Audio board, than see what happens.
    Nov 2016
    Rimini - Italy
    101
    For completeness: after formatting, using normal speed playback, the report shows more or less same values and same behave:
    1  7
    2  217
    3  7
    4  2143
    5  7
    6  217
    7  7
    8  217
    9  8
    10  217
    11  7
    12  217
    13  7
    14  217
    15  7
    16  215
    17  7
    18  2141
    19  7
    20  215
    21  7
    22  217
    23  7
    24  217
    25  7
    26  217
    27  8
    28  217
    29  8
    30  217
    Germany NRW
    5,811
    Not sure if this is the reason, am using my phone to write this answer and can't look at the internal SD Code - but it would explain the behaviour if the SD lib internally buffers one block - which 512 Bytes. In your upper version of your code, you read 128*2=256 bytes, the half of a block - which may be got read already and thus is much faster for every 2nd read.
    Nov 2016
    Rimini - Italy
    101
    I got it...Ok, thank you Frank for the explantion!
    10,327
    Same thought here - but in glancing the code misread 'AUDIO_BLOCK_SAMPLES * 2' as requesting two blocks …
    That explains the "playback at double speed" read having that same time on each time measure.
    Just for ref this thread has notes on using 8 MB psRAM on SPI at 80 MHz : PC-Engine-emulator-PSRAM-experiment
    Nov 2016
    Rimini - Italy
    101
    Question
    Going back to W25Q256..
    I read on Audio shield schematics (where an 8-pin flash memory IC is contemplated), that "RST" is indicated. While on 8pin ICs (like W25Q128) /RESET and /HOLD use the same pin, on W25Q256 (16pin) /HOLD and RESET/ are separated on different pins:
    Does anybody know which of them must be connected to 3.3V? Both? only /RESET?
    thank you
    Nov 2017
    Belgium
    187
    Both /RESET and /HOLD need to be connected to 3.3V.
    Nov 2016
    Rimini - Italy
    101
    Quote Originally Posted by neurofun View Post
    Good, thank you Neurofun. I'm designing a small pcb for the W25Q256, with a groudplane, to be soldered toghether with the Audio shield (on top, or below) ... let's see how it will perform.
    Nov 2016
    Rimini - Italy
    101
    A bad mistake I did here... i had connected the flash chip GND pin to Analog GND... shame on me.
    Anyway, now the small PCB is done; i'm testing it, seems working fine.
