Having an issue using SPI on Teensy 2.0
Organism
New member
I am trying to port a project from Arduino to Teensy 2.0 and having a small issue. The Teensy is connect to a TLV5618 DAC in order to convert digital to voltage. I originally built it on my Arduino Uno where it works, I setup the pins for Teensy and the scope is flat still. The code is borrowed from http://www.stephenhobley.com/build/lh_arduino.html
My code:
//  Signal      Function      Teensy 2.0      TLV5618
//  SS          Select Device   0               CS (3) (Green wire)
//  SCK         Clock           1               SCLK (2) (Blue wire)
//  MOSI        Data Output     2               DIN (1) (Yellow wire)
// DAC Data Transfer
#define SLAVESELECT 0 // CS (SS)
#define SPICLOCK 1 // SCLK
#define DATAOUT 2 // DIN
long randVoltage;
short randTime;
  // Setup SPI Interface code BEGIN ///////////////////////////////////////////
  byte clr;
  pinMode(DATAOUT,OUTPUT);
  pinMode(SPICLOCK,OUTPUT);
  pinMode(SLAVESELECT,OUTPUT);
  digitalWrite(SLAVESELECT,HIGH); //disable device
  //The SPI control register (SPCR) has 8 bits, each of which control a particular SPI setting.
  // SPCR
  // | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |0000000000000000000
  // | SPIE | SPE | DORD | MSTR | CPOL | CPHA | SPR1 | SPR0 |
  // SPIE - Enables the SPI interrupt when 1
  // SPE - Enables the SPI when 1
  // DORD - Sends data least Significant Bit First when 1, most Significant Bit first when 0
  // MSTR - Sets the Arduino in master mode when 1, slave mode when 0
  // CPOL - Sets the data clock to be idle when high if set to 1, idle when low if set to 0
  // CPHA - Samples data on the falling edge of the data clock when 1, rising edge when 0'
  // SPR1 and SPR0 - Sets the SPI speed, 00 is fastest (4MHz) 11 is slowest (250KHz)
  SPCR = (1<<SPE)|(1<<MSTR)|(1<<CPHA);
  clr=SPSR;
  clr=SPDR;
  delay(20);
  randVoltage=random(4095);
  randTime=random(500);
  delay(randTime);
  SetVoltage(randVoltage);
//  delay(20);
//  SetVoltage(3000);
//  delay(20);
//  SetVoltage(350);
  // DAC SPI Interface
  char spi_transfer(volatile char data) {
    SPDR = data; // Start the transmission
    // Wait the end of the transmission
    while (!(SPSR & (1<<SPIF))) {
    return SPDR; // return the received byte
  // Set the voltage on the 12bit DAC
  byte SetVoltage(short Voltage) {
    Voltage = Voltage | 32768; // Use DAC A
    digitalWrite(SLAVESELECT,LOW);
    //2 byte opcode -- for some reason we have to do this twice to make it stick with the TLV5618
    spi_transfer(Voltage>>8);
    spi_transfer(Voltage);
    digitalWrite(SLAVESELECT,HIGH); //release chip, signal end transfer
The wiring diagram
Thanks for your time and thoughts
