Results 1 to 9 of 9
Thread: sending data over CAN from teensy
    I am using the improved flex can library and I have it reading Messages fine using
       FRWJCAN =msg.buf[2]*256 +msg.buf[3];
          if (FRWJCAN> 32768)
             FRP = (FRWJCAN- 65536)*1.00;
             FRP = FRWJCAN*1.00;
    to read a specific can message and wrapping it if it goes negative.
    What i want to do is send internal temp ( of the teensy3.6 on any CAN id)
    any ideas of how i can do that? I am using SN65HVD230D transceivers.
    Thank you!
    Dec 2016
    Montreal, Canada
    3,268
    You mean like the sending struct?
    CAN_message_t msg;
    msg.id = 0x123;
    msg.flags.extended = 0;
    msg.len = 8;
    msg.buf[0] = myTemperature;
    Can0.write(msg);
    As for keeping a value positive, you can use abs()
    abs(-10.6);
    abs(18);
    Output:
    18
    CAN_message_t msg;
    msg.id = 0x123;
    msg.len = 8;
    Can0.write(msg);
    abs(-10.6);
    abs(18);
    Output:
    18
    Hey i have copy and pasted that code and i dont get any value at all im assuming its big endian which means the start bit is 8
    Do i need the CAN_message_t msg; if its called up earlier in the packet? I dont get any errors or anything but I just dont get anything on my logger side.
    Any ideas?
    Dec 2016
    Montreal, Canada
    3,268
    It should be sent fine. What does mailboxStatus() display?
    Are you using IFCT or FlexCAN_T4?
    You have proper terminations on the CAN endpoints?
    I dont have any idea on the mailbox status as i cant currently send to it because we are using it for testing over the next couple days and its working fine for the test as is.
    I am using IFCT
    The thing i am trying to do is send teensy cpu temp over CAN to monitor temp as it has overheated in the past.
    I have the termination correct because I am able to see values on the teensy that I send over CAN too it I just dont know how to send it or its not sending properly.
    I will try and post code tonight to try and show you what i got going on. It compiles fine and its exactly what you wrote so im unsure as to why its not working.
    #include <IFCT.h>
    #define qBlink() (digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN) ))
    #include <InternalTemperature.h>
    InternalTemperature temperature;
    // variable declaration ************************
    int TempCount = 0;
      //**** Setting pin outputs
      delay(10000);
      //******* CAN SETUP *****************
      pinMode(28, OUTPUT); // for the transceiver enable pin
      digitalWrite(28, LOW); // Low for HIGH speed
      Can0.setTX(ALT); // for pin 29
      Can0.setRX(ALT); // for pin 30
      Can0.setBaudRate(1000000); // matches PI System
      Can0.enableFIFO(); // First in first out CAN style
      CAN_message_t msg;
      if ( Can0.read(msg))
        if (msg.id == 613) // 265 HEX
          FCAN = msg.buf[0] * 256 + msg.buf[1];
          if (FCAN > 32768)
            F = (FCAN - 65536) / 100.00;
            F = FCAN / 100.00;
        // Displays internal temp of Teensy
        if (TempCount >= 1000)
          Serial.print("Temperature: ");
          Serial.print(temperature.readTemperatureC(), 1);
          Serial.println("C");
          CAN_message_t msg;
          msg.id = 0x617;
          msg.len = 8;
          msg.buf[0] = temperature.readTemperatureC();
          Can0.write(msg);
          TempCount = 0;
        TempCount++;
    So I just relized in my If can read is my can send, do I need to do that in my else outside of that loop? or can i do it how I have it?
    @tonton81
    Dec 2016
    Montreal, Canada
    3,268
    Yes that means it will never send unless you keep receiving that frame until tempcount hits target, intentionaly? If not, take it out of the read statement
    Ok so Ill pop that out of that read statement and do another statement that if the counter get too 1000 then do that write. I just dont want it to send at 10khz for a temp signal so making it update at 1hz is more than enough.
    So hopefully that will work. If i just copy your statement it should just be plug and play correct?
    Dec 2016
    Montreal, Canada
    3,268
    You can use millis() to time it at once per second:
    static uint32_t resend = millis();
    if ( millis() - resend > 1000 ) {
      // send CAN frame code here
      resend = millis();
