Results 1 to 2 of 2
Thread: sending data over CAN from teensy
    Jun 2019
    16
    I am using the improved flex can library and I have it reading Messages fine using
       FRWJCAN =msg.buf[2]*256 +msg.buf[3];
          if (FRWJCAN> 32768)
             FRP = (FRWJCAN- 65536)*1.00;
             FRP = FRWJCAN*1.00;
    to read a specific can message and wrapping it if it goes negative.
    What i want to do is send internal temp ( of the teensy3.6 on any CAN id)
    any ideas of how i can do that? I am using SN65HVD230D transceivers.
    Thank you!
    Dec 2016
    Montreal, Canada
    3,204
    You mean like the sending struct?
    CAN_message_t msg;
    msg.id = 0x123;
    msg.flags.extended = 0;
    msg.len = 8;
    msg.buf[0] = myTemperature;
    Can0.write(msg);
    As for keeping a value positive, you can use abs()
    abs(-10.6);
    abs(18);
    Output:
    18
