Results 1 to 2 of 2
Thread: adcHighPassFilterEnable();
    Nov 2019
    6
    Hello guys,
    I am doing some audio project with tennsy 3.2 + audio board. Now i've calibrated microphone on audio board and adjuted to show the decibels. I think that works quite fine.
    I also found option "adcHighPassFilterEnable();". If I understand correctly, this function is used by default, even if I don't use it and it cut the low frequency noises?
    Does it works like A-weighting? Can I somehow set the border frequency of filtering (in case if cuts "too much").
    ""By default, the analog input (either line-level inputs or mic) is high-pass filtered, to remove any DC component.""
    Every answer will be helpfull.
    Best regards,
    Oct 2015
    Vermont, USA
    230
    Personaly, I always disable that ADC filter as I find that it adds unacceptable noise to the system. See my post on this issue here:
    http://openaudio.blogspot.com/2017/0...noise.html?m=1
    If you choose to disable the adc's highpass filter, you will have a small DC offset in your audio stream. You can remove this by adding a highpass filter using one of the filter blocks in the Teensy Audio Library (or using your A weighting filter, which also filters away DC). I have no problem with filtering; I only have a problem with the specific implementation of the HP filter used by default in the ADC.
    Chip
