Results 1 to 2 of 2
Thread: Teensy 3.5 Coding Problem
    Dec 2019
    17
    Hey guys,
    I am designing a usb midi controller using a Teensy 3.5 with 12 tactile buttons and 20 rotary encoders (KY-040 no push button). I have no problem physically connecting everything, though I am having a hard time understanding coding and can't decipher the meanings of things. I have attached a chart below which shows the pins that each component is connected to.
    I understand it is a lot to ask to write all of this code, though if someone can please write the code for 2 buttons and 2 rotary encoders (with all other variables needed), I can just copy that code to my other components. I very much appreciate your assistance. Thank you!!!
    Teensy 3.5 Routing Chart.pdf
    21,073
    Please do not create duplicate threads.
    https://forum.pjrc.com/threads/58632...Coding-Problem
