Page 1 of 2 1 2 LastLast
Results 1 to 25 of 45
Thread: Teensyduino 1.49 Beta #2
    Administrator Paul's Avatar
    Oct 2012
    390
    Here is a second beta test for Teensyduino 1.49.
    EDIT: links removed, please use 1.49-beta3
    Changes since Teensyduino 1.49-beta1
    Add Teensy 4.0 USB MIDI, Keyboard, Mouse, Joystick
    Support for MacOS Catalina
    Port WS2812Serial to Teensy 4.0 (KurtE)
    AVR register emulation on Teensy 4.0 (KurtE)
    Fix serial DMA def on Teensy 4.0 (KurtE)
    Improve ADC & XBAR defs on Teensy 4.0 (KurtE)
    Improve quadrature encoder defs on Teensy 4.0 (mjs513)
    Add Teensy 4.0 USB Touchscreen, not finished... work in progress
    Remove serial monitor debug messages on Arduino 1.8.9
    New York
    6,967
    @Paul
    Downloaded and installed Beta2 with no issues whatsoever. Did see all the new USB stuff in the IDE dropdowns.
    Out of curiosity I tried to run the keyboard simple example but my PC is having issues with it. Never used the usb stuff before so maybe it is me. Anyway, first run I had SerMon open and I saw the hello wrld displayed in the sermon. My PC then said it created a new Keyboard but then it went all of a sudden it logged me off and the my logon screen displayed and then I was stuck so I just hit restart.
    Next run I had notepad open and plugged the T4 in again and again it went even crazier. My web browser pop upped, then the xbox gaming app opened, and then it wanted to install tycommander so I just unplugged the T4 to get control back. Not sure this is the desired behavior.
    For reference I am on a Windows 10 x64 machine.
    24,090
    I'll confess... I tested the new USB stuff mostly with Linux and a quick check on Mac, but not Windows. I use Linux as my primary system, and the Macbook Air was set up due to the recent work on MacOS Catalina support.
    I did watch the communication with the Beagle 480 protocol analyzer.
    Looks like I'll need to get my Windows 10 test machine out later today! Can you tell me exactly which example you ran? Was any other hardware connected to your Teensy 4.0 during the test?
    New York
    6,967
    Morning again.
    Anyway, ran the Simple USB Keyboard Example, simple.ino, under keyboard examples. Nothing else was hooked up to the T4. Was using a the Ultimate T4 breakout board I got off Tindie. Reason - it was handy. It did have a SD card in the its SD Socket.
    Also, just in case it might have been the breakout board I tested with one of my breakouts that I have been using with nothing additional on the board. All it does is bring the pins on the T4 out to the headers. It exhibited the exact same behavior.
    13,918
    Downloaded and installed TD 1.49b2 for some reason this time it gave this on first run - I did not pick "Run":
    Looked at properties and it offered 'UNBLOCK', I did not check that and re-ran the download and it completed without issue or prompt from Windows 10.
    Re: Clock issue Failure of Micros() at some speeds - that does repro at 24 MHz. I edited compile to start at 150 MHz and that does work properly - updated in post. Edited code there as it was missing a 0 when asking for 150MHz - it was type 15 MHz.
    Accidentally had "USB Serial=S/M/K/J" on other sketch and Windows gave this:Click image for larger version.
    Ran the 'Simple.ino' and got 3 things to close and nothing in notepad - T4 with nothing connected: Excel, OneDrive, Browser page to 'Linked In', also TyCommander display page changed.
    This "T:\arduino_1.8.10\examples\09.USB\Keyboard\Keyboa rdSerial\KeyboardSerial.ino" won't build 'keyboard' or 'Ser + Mouse + Key + Joy'
    T:\arduino_1.8.10\arduino-builder -dump-prefs -logger=machine -hardware T:\arduino_1.8.10\hardware -hardware C:\Users\Tim\AppData\Local\Arduino15\packages -hardware T:\tCode\hardware -tools T:\arduino_1.8.10\tools-builder -tools T:\arduino_1.8.10\hardware\tools\avr -tools C:\Users\Tim\AppData\Local\Arduino15\packages -built-in-libraries T:\arduino_1.8.10\libraries -libraries T:\tCode\libraries -fqbn=teensy:avr:teensy40:usb=keyboard,speed=600,op t=o2std,keys=en-us -ide-version=10810 -build-path T:\TEMP\arduino_build_750081 -warnings=more -build-cache T:\TEMP\arduino_cache_493927 -verbose T:\arduino_1.8.10\examples\09.USB\Keyboard\Keyboar dSerial\KeyboardSerial.ino
    T:\arduino_1.8.10\arduino-builder -compile -logger=machine -hardware T:\arduino_1.8.10\hardware -hardware C:\Users\Tim\AppData\Local\Arduino15\packages -hardware T:\tCode\hardware -tools T:\arduino_1.8.10\tools-builder -tools T:\arduino_1.8.10\hardware\tools\avr -tools C:\Users\Tim\AppData\Local\Arduino15\packages -built-in-libraries T:\arduino_1.8.10\libraries -libraries T:\tCode\libraries -fqbn=teensy:avr:teensy40:usb=keyboard,speed=600,op t=o2std,keys=en-us -ide-version=10810 -build-path T:\TEMP\arduino_build_750081 -warnings=more -build-cache T:\TEMP\arduino_cache_493927 -verbose T:\arduino_1.8.10\examples\09.USB\Keyboard\Keyboar dSerial\KeyboardSerial.ino
    Using board 'teensy40' from platform in folder: T:\arduino_1.8.10\hardware\teensy\avr
    Using core 'teensy4' from platform in folder: T:\arduino_1.8.10\hardware\teensy\avr
    Detecting libraries used...
    "T:\\arduino_1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=149 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IT:\\arduino_1.8.10\\hardware\\teensy\\avr\\cores\ \teensy4" "T:\\TEMP\\arduino_build_750081\\sketch\\KeyboardS erial.ino.cpp" -o nul
    Alternatives for Keyboard.h: [Keyboard@1.0.2]
    ResolveLibrary(Keyboard.h)
    -> candidates: [Keyboard@1.0.2]
    "T:\\arduino_1.8.10\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=149 -DARDUINO=10810 -DF_CPU=600000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IT:\\arduino_1.8.10\\hardware\\teensy\\avr\\cores\ \teensy4" "-IT:\\arduino_1.8.10\\libraries\\Keyboard\\src" "T:\\TEMP\\arduino_build_750081\\sketch\\KeyboardS erial.ino.cpp" -o nul
    Alternatives for HID.h: []
    In file included from T:\arduino_1.8.10\examples\09.USB\Keyboard\Keyboar dSerial\KeyboardSerial.ino:22:0:
    ResolveLibrary(HID.h)
    T:\arduino_1.8.10\libraries\Keyboard\src/Keyboard.h:25:17: fatal error: HID.h: No such file or directory
    -> candidates: []
    compilation terminated.
    Multiple libraries were found for "Keyboard.h"
    Used: T:\arduino_1.8.10\libraries\Keyboard
    Using library Keyboard at version 1.0.2 in folder: T:\arduino_1.8.10\libraries\Keyboard
    Error compiling for board Teensy 4.0.
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    156
    Installed on linux mint 19.2 Tina, XFCE desktop, Arduino 1.8.10
    USB Midi example " InputRead " works as expected.
    USB Keyboard example "Simple"... "all hell" breaks loose. Random applications launched, ' Start menu' opens, volume control activates.
    Mar 2014
    New Ulm, Mn
    156
    attached T4 previously flashed with "Keyboard Simple" sketch to windows 10 notebook computer. It rebooted, and failed to acknowledge the built in keyboard. Another reboot corrected this.
    A second attempt to connect it with setting opened to devices page... device found, but same results immediately afterward... reboot, locked out of default keyboard device.
    Apr 2017
    732
    The Catalina one is still using Teensyduino 1.49 beta 1.
Name:	Screen Shot 2019-12-10 at 2.31.20 PM.png
    Sep 2017
    Italia
    87
    Windows 10 Pro 1909 x64 build 18363.476
    Trying to run example "Teensy USB_MIDI Buttons"
    CPU Speed: "600MHz" (default)
    Optimize: "Faster" (default)
    USB Type: "MIDI"
    Windows builtin MIDI driver: Device driver not started (code 10), "nonpresent device"
    Korg USB MIDI driver 1.15.31.2 (recent): Driver loads and starts, exactly one "Note on" gets through, then no communication any more. T4 keeps on running.
    USB Type: "Serial + MIDI"
    Does not compile. Arduino errors:
    Arduino: 1.8.10 (Windows 10), TD: 1.49-beta2, Board: "Teensy 4.0, Serial + MIDI, 600 MHz, Faster, US International"
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_desc.c:683:13: error: 'CDC_RX_SIZE_480' undeclared here (not in a function)
             LSB(CDC_RX_SIZE_480),MSB(CDC_RX_SIZE_480),// wMaxPacketSize
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_desc.c:64:18: note: in definition of macro 'LSB'
     #define LSB(n) ((n) & 255)
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_desc.c:690:13: error: 'CDC_TX_SIZE_480' undeclared here (not in a function)
             LSB(CDC_TX_SIZE_480),MSB(CDC_TX_SIZE_480),// wMaxPacketSize
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_desc.c:1517:13: error: 'CDC_RX_SIZE_12' undeclared here (not in a function)
             LSB(CDC_RX_SIZE_12),MSB(CDC_RX_SIZE_12),// wMaxPacketSize
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_desc.c:1524:13: error: 'CDC_TX_SIZE_12' undeclared here (not in a function)
             LSB(CDC_TX_SIZE_12),MSB(CDC_TX_SIZE_12),// wMaxPacketSize
    Multiple libraries were found for "Bounce.h"
     Used: C:\Program
    Dec 2015
    LA
    202
    Quote Originally Posted by vjmuzik View Post
    Well the Arduino window says beta 1, but launches beta 2.
    Don't see anything but serial for T4 USB Type.
Name:	Image 12-10-19 at 12.12 PM.jpg
    Installed no other problems on Catalina. I had previously deleted beta1 and cleared all the Arduino related 'Security and Privacy' preferences to give it a good test.
    Apr 2017
    732
    Teensy Loader does say beta 2, but nothing has been changed in the cores folder like it should be.
    Nov 2017
    Belgium
    214
    MacOS 10.13.6
    USB Type: "MIDI"
    Works in both directions, IN/OUT.
    Does not compile.
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/usb_desc.c:683:13: error: 'CDC_RX_SIZE_480' undeclared here (not in a function)
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/usb_desc.c:64:18: note: in definition of macro 'LSB'
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/usb_desc.c:690:13: error: 'CDC_TX_SIZE_480' undeclared here (not in a function)
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/usb_desc.c:1517:13: error: 'CDC_RX_SIZE_12' undeclared here (not in a function)
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/usb_desc.c:1524:13: error: 'CDC_TX_SIZE_12' undeclared here (not in a function)
    Apr 2017
    732
    After installing MacOS-X 10.8 to 10.14 over the MacOS Catalina 10.15 app I can confirm the same bug with "Serial + MIDI", but after compiling with normal "MIDI" it seems to work as expected while doing a simple loopback test with seemingly no issues so far. MacOS detects it as it should along with name.c as well and after determining that all of the various midi messages go through and come back as expected I think MIDI is sorted out as long as there are no differences between the T3.6 and T4.0 send and receive functions that would make it work different since I didn't test all of them.
    Here's the loopback code if anyone else wants to test it real easy.
    uint32_t message;
      message = usb_midi_read_message();
      if(message) {
        Serial.print("   Message: ");
        Serial.println(message, HEX);
        usb_midi_write_packed(message);
    Nov 2017
    Belgium
    214
    Quote Originally Posted by neurofun View Post
    MacOS 10.13.6
    USB Type: "MIDI"
    Does not compile.
    Follow up:
    USB Type: "MIDI" seems to act like "Serial + MIDI" since Serial.print() still shows up in serial monitor.
    Apr 2017
    732
    Follow up:
    That is by design, but it’s not Serial being that it won’t work with normal serial monitors since it’s a special HID serial emulation designed for the Teensy monitor. All previous Teensy devices have had the same emulation in the past.
    Nov 2017
    Belgium
    214
    I was slightly confused when the teensy didn't show up as a usb serial device and the Serial.print() still worked.
    It all makes sense now. Thanks for the clarification.
    24,090
    Quote Originally Posted by bicycleguy View Post
    Opps, I messed up the MacOS Catalina build. Fixed it just now and uploaded a fresh file.
    The new Teensyduino_MacOS_Catalina.zip has shasum e72ba892097e5f849f71706d8b14d2abaea14926.
    The original Teensyduino_MacOS_Catalina.zip is still on the server with file renamed. It has shasum bf8e3b3b16891131b700cf82b695fd4c8425fe06.
    My build process for this Catalina download still involves many manual steps. I skipped automating it, so I could get back to work on the missing USB types. Just now I started the beginning of a script which should help, though it's still need more work to be reasonably well automated like the other builds.
    Dec 2015
    LA
    202
    ...Fixed it just now and uploaded a fresh file.
    Works great! Thanks for the shasum too, clears some of my rev. - dyslexia
    Mar 2017
    Oakland, CA, USA
    190
    I've seen two issues with the Catalina install (running on Mojave):
    1. When I open the search box with cmd-F the first time after a fresh open, and I start typing, the first few characters in my search always go into the editor instead of the search box. This doesn't happen with the regular Arduino 1.8.10 IDE, nor does it happen if I wait a few seconds before typing into the search box. I've seen this with both Beta #1 and Beta #2.
    2. When I try to close a window that has edited content, and I select "Don't Save", I've seen that window never close and I have to quit the app to get it to close. I haven't seen this lately, though. I've only seen this a few times with Beta #1 and not yet with Beta #2.
    These issues may very well have nothing to do with Paul's build and instead have to do with OSX or the Arduino code itself. Just thought I'd report anyway. I'm running the very latest 10.14.6 with all the latest updates.
    Sep 2017
    Italia
    87
    Catalina is so full of bugs, it should be disregarded until the issues are fixed by the costermongers.
    Apr 2017
    732
    Quote Originally Posted by shawn View Post
    After running some quick tests I haven't been able to reproduce either of your issues using the latest MacOS Catalina 10.15.2 to any degree of certainty, on the first launch of the IDE when doing cmd-f the search window is a little slow to open by a couple of seconds but after the first open it does launch nearly instantly and doesn't misplace any keystrokes in the wrong window. As far as the second issue I haven't had that happen to me yet, not while using beta 1 or beta 2 so it may just be an issue of running the Catalina app on the older MacOS versions.
    24,090
    Quote Originally Posted by ETMoody3 View Post
    I committed a fix for this problem.
    https://github.com/PaulStoffregen/co...2b8a7af652cf49
    Can't say I'm proud of having to add a 30 ns delay. I still don't understand *why* the status word is saying the transfer status is ready before it's actually ready.
    24,090
    Quote Originally Posted by radias View Post
    Does not compile.
    Opps. Fixed it.
    https://github.com/PaulStoffregen/co...7129dd7d4c77a8
    New York
    6,967
    Just downloaded and copied the changed files and gave the "simple.ino" keyboard sketch a try on my Windows10x64 desktop. Looks like the solved the issue with all "hell" breaks loose. Did confirm that it actually prints to what ever window you have active - so be careful .
    24,090
    I'm going to package up 1.49-beta3 soon.
    Now's the time to remind me of stuff I've forgotten to test or merge....
