analogRead() vs Frequency on T4
marcoconti
New member
I modified an example of code to determine the approximate speed of Teensy 4's analogRead() at 600Mhz; then, I tested different clock speeds ranging from from 24Mhz to 816Mhz to see if changing frequency led to slower or faster read speeds.
I noted that clock speed changes -apparently- did not affect the speed of the analogRead(); analogRead() took approximately 5 microseconds inside a for cycle and it did not move from there.
Is the analogRead() speed always a constant unrelated to the clock speed?
The code below explained: It take a start time with micros(). Executes 100 times analogRead() by a For{}. Takes the end time of the For{} and determines the average time needed by one analogRead() operation. 5 microsends.
#define VREF (3.292)         // ADC reference voltage (= power supply)
#define VINPUT (1.328)       // ADC input voltage from NiCd AA battery
#define ADCMAX (4095)        // maximum possible reading from ADC
#define EXPECTED (ADCMAX*(VINPUT/VREF))     // expected ADC reading
#define SAMPLES (1)      // how many samples to combine for pp, std.dev statistics
const int analogInPin = A0;  // Analog input is AIN0 (Teensy3 pin 14, next to LED)
const int LED1 = 13;         // output LED connected on Arduino digital pin 13
int sensorValue = 0;        // value read from the ADC input
unsigned long StartTime=0;
unsigned long TotTime=0;
unsigned long ReadTimeUnit=0;
int x=0;
void setup() {    // ==============================================================
      pinMode(LED1,OUTPUT);       // enable digital output for turning on LED indicator
      // analogReference(EXTERNAL);  // set analog reference to internal ref
      analogReadRes(12);          // set ADC resolution to this many bits
      analogReadAveraging(SAMPLES);    // average this many readings
      Serial.begin(115200);       // baud rate is ignored with Teensy USB ACM i/o
      digitalWrite(LED1,HIGH);   delay(1000);   // LED on for 1 second
      digitalWrite(LED1,LOW);    delay(3000);   // wait in case serial monitor still opening
      Serial.println("# Teensy ADC test start: ");
} // ==== end setup() ===========
void loop() {  // ================================================================
      StartTime = micros();   // record start time in microseconds
      for (int i=0;i<100;i++) {
      x = analogRead(analogInPin);
      TotTime = micros()-StartTime;   // record duration in microseconds
      ReadTimeUnit=TotTime/100;
      Serial.print("Microseconds/ADC-Read: ");
      Serial.print(ReadTimeUnit,DEC);
      Serial.print("     ADC VALUE: ");
      Serial.print(x, DEC);
