Curious about serial1.c uart0_status_isr() and a teensy 3.6
Hi, I've just started to get into ARM programming. Up until now I've only used Arduino and some other tool chains / APIs that didn't require me to think too hard about what is going on under the hood.
My understanding of how the T3.6 UART works is - an interrupt routine
void uart0_status_isr(void)
is passing incoming characters to a fifo, that needs to be cleared by the higher level arduino serial handling functions.
I am curious how / where
is actually turned into an interrupt?
I have searched the entire Arduino directory for "uart0_status_isr" and only find references in:
"C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\kinetis.h"
extern void uart0_status_isr(void);
"C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial1.c"
//The isr code...
"C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\mk20dx128.c"
void uart0_status_isr(void)	__attribute__ ((weak, alias("unused_isr")));
I searched for NVIC and I see functions to enable and disable interrupts, but I don't see where uart0_status_isr(void) is actually defined as the interrupt routine for IRQ_UART0_STATUS.
I'm just curious... Thanks!
Thanks Paul! There's the missing piece.
I must have searched for "uart0_status_isr(" (including the opening parenthesis) and that's why I didn't get that reference in my results.
I *really* do want to learn ARM! I just got the definitive guide in the mail last week. Birthday present to myself... She's a beast.
Thanks again.
