Results 1 to 2 of 2
Thread: Audio Shield lino out x 4 by OP-AMP
    Oct 2016
    181
    Hi, do u have suggestions for a schematic op-amp amplifier x4 db working for the output of Teensy Audio Shield...
    TL074 ic is the best way?
    Is there a schematic example available for this?
    Thank u
    Dani
    Aug 2016
    Australia
    64
    there are many suitable preamp modules available on eBay that will do the trick. most need a 12 v supply.
    The AD828 based ones might do the trick, as they will run on 5v. Beware, though that with a voltage gain of 4 (12dB) you will run out of headroom at 5v, with even a modest signal.
    I hope that helps.
