Results 1 to 4 of 4
Thread: MahonyIMU buid error :- 'class mahony' has no member named 'begin'
    Nov 2019
    3
    I am trying to build MahonyIMU but I get error :- 'class mahony' has no member named 'begin'
    and if I look in MahonyAHRS.h (downloaded using Library Manager) then there is no 'begin'
    Totally confused
    1,212
    I'm using Arduino 1.8.10 and Teensyduino 1.49b2. I can compile the PropShield example in the Mahony library and MahonyAHRS.h (installed with Teensyduino) does contain begin().
    Which version of Arduino and TD are you using?
    Pete
    Nov 2019
    3
    Its a brand new Arduino install (today) 1.8.10 with latest Teensyduino. I was able to do the prop shield calibration
    Yes, I now see that the PropShield example in the Mahony library compiles . But now I get "Teensy did not respond to a USB-based request to enter program mode.". and pressing the button on the teensy 3.2 does not seem to help
    I was originally trying MahonyIMU in NXPMotionSense. following http://crispycircuits.blogspot.com/2...d-tracker.html
    I also installed (Library Manager) Mahony 1.1.0 which seemed to fix an earlier error. I wonder whre the .begin method is
    My goal is an "air mouse" ie a teensy on my head
    4,579
    Quote Originally Posted by peterc View Post
    Well lets start with this. The MahonyIMU.ino sketch uses the PRJC MahonyAHRS library. Do not believe this is the same as the one you download with library manager, just a guess here.
    However, the MahonyAHRS lib can be downloaded from here: https://github.com/PaulStoffregen/MahonyAHRS, if not already installed in the teensy library folder.
    In the MahonyAHRS.h file from the library begin is defined as:
    void begin(float sampleFrequency) { invSampleFreq = 1.0f / sampleFrequency; }
    So suggestion is to download the that library and give it a try.
