Results 1 to 7 of 7
Thread: Flexible Array in Arduino ?
    Senior Member Jp3141's Avatar
    461
    I am trying to initialize an array as part of a structure variable, but the compiler options in place on Arduino seem to require that the array size is predefined. Is there a way around this ? Ultimately, different instances of my Key structs will have different lengths for the Pulse[] array and I don't want to reserve memory for the worst (longest) case.
    Here is a very reduced version of my code;
    struct Key {
      char Name[8];
      unsigned int Pulse[11]; // works
      //unsigned int Pulse[];   // get compiler message about "too many initializers for 'unsigned int [0]'"
    struct Key OnKey =     {"On",     {9070,4480, 610,530, 600,530, 610,520, 600,530, 00}};
    void setup() {}
    void loop() { }
    21,089
    Quote Originally Posted by Jp3141 View Post
    There is no easy way. Arrays in C++ are fixed length.
    You can create a C++ class, which isn't really an array at all, but tries to act like one with operator overloading syntax. Then code inside your class can use malloc or new to dynamically allocate memory as needed. Arduino's String class does this, if you need an example for inspiration.
    Many people consider use of malloc/new controversial for embedded code, due to possible memory fragmentation and non-deterministic timing. Those might be issue to consider in the design of your special C++ class, should you decide to go down that path.
    Apr 2017
    Florida
    452
    I’ve been playing around with new and delete for creating variable wavetable arrays from an SD card for dynamic wavetable synthesis instead of being limited to what fits in flash memory. Caution definitely needs to be taken place to make sure there are no memory leaks or collisions, but it is possible although like Paul says it’s controversial for microcontrollers.
    you could do something along the lines of:
    struct Key {
      char Name[8];
      unsigned int *Pulse;
    unsigned int pulseOn[]={9070,4480, 610,530, 600,530, 610,520, 600,530, 00};
    Key keyOn = {"On", pulseOn};
    461
    Thanks @JarkkoL -- that's closer to what I was aiming for, but I was hoping (for clarity) to have it all on one line without having to invent new names for all the intermediate variables like pulseOn[] -- I'll have a couple of dozen of those.
    I guess C can't do something like:
    Key keyOn = {"On", &{9070,4480, 610,530, 600,530, 610,520, 600,530, 00}};
    where the address of the list of integers is added to the structure ? ( but I guess that is what is happing with the string for the Name ?)
    Also, the
     pulse[]
    syntax and
    work on gcc on my Mac. It seems to be a feature of C99 -- does Arduino use that ?
    Well, if you absolutely want to take a trip to the syntax crazy land:
    #define KEY(name__, ...) unsigned int pulse##name__[]=__VA_ARGS__;\
                             Key key##name__={#name__, pulse##name__}
    KEY(On, {9070,4480, 610,530, 600,530, 610,520, 600,530, 00});
    Edit: Just to clarify, I don't advocate this kind of code because it silently introduces new identifiers to your code and causes extra indirection that you mentally have to jump through when reading code... just to make the syntax appear slightly cleaner outside. IOW, it's a bad compromise, IMO
    461
    Thanks -- that works, but I agree it's quite twisted; I'll wait until I am really out of memory.
