Results 1 to 3 of 3
Thread: qvgatest_touch purple board USB power?
    The qvgatest_touch arrived (https://oshpark.com/shared_projects/TG395I75), thanks for making this pcb, Paul.
    Is there a straightforward way to wire the qvgatest_touch to power the ILI9341 from Teensyduino USB power, instead of the DC power jack?
    22,123
    Sure, just built it without the DC power jack and 7805 voltage regulator. And of course do *not* cut the VUSB-VIN pads apart on your Teensy (or solder them back together if already cut apart) so your Teensy provides 5V power.
    Thanks Paul, will give this a go!
