As I am venturing into using the Teensy for audio processing, I have encountered a speedbump.
I have a 3.5mm TRRS jack wired up to pin 16 (A2) on my Teensy 4.0 following the suggested circuit on the design tool (shown below).
I wanted to test the input so I loaded up the "PeakMeterMono" sketch that is included under the audio examples, but when I try to compile and run the program completed unedited, I get an "Error compiling for board Teensy 4.0".
Full error code is here:
The same error occurs anytime I try to use a sketch that contains AudioInputAnalog it seems. Is there any fix to this, or do I just need to bite the bullet and buy an audio shield to wire the 3.5mm jack to?
Arduino: 1.8.10 (Windows 10), TD: 1.48, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
C:\Users\---\AppData\Local\Temp\arduino_build_262521\sketch\PeakMeterMono.ino.cpp.o: In function `AudioInputAnalog::AudioInputAnalog()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/input_adc.h:37: undefined reference to `AudioInputAnalog::init(unsigned char)'
C:\Users\---\AppData\Local\Temp\arduino_build_262521\sketch\PeakMeterMono.ino.cpp.o: In function `AudioStream::AudioStream(unsigned char, audio_block_struct**)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h:130: undefined reference to `vtable for AudioInputAnalog'
Multiple libraries were found for "Audio.h"
Used: C:\Program
Multiple libraries were found for "SPI.h"
Used: C:\Program
Used: C:\Users\---\Documents\Arduino\libraries\SD
Not used: C:\Program
Multiple libraries were found for "SerialFlash.h"
Used: C:\Program
Multiple libraries were found for "Wire.h"
Used: C:\Program
Error compiling for board Teensy 4.0.
