I am trying to recieve midi via the USB port, while the Teensy is connected to the PC via it. After doing a little searching on the forums I tried a few midi patching solutions like loopMidi and Midi Ox to gain a better insight into my issue: Running any of the generic usb midi examples, I am unable to get the 3.6 to respond to incoming midi signal routed to the Teensy. Eventually I just routed midi ox directly to the teensy and sent test signals. The signals were confirmed as being sent and recieved by Midi Ox monitor however, there is no serial acknowledgment of the midi being recieved. Ditto for the led midi sketch. I did make sure to set the serial mode to MIDI before compiling. Anyways, after pulling my hair out for a few hours I decided it might be wise to just ask here, as I didn't find an answer searching through the forum.
Can the Teensy 3.6 currently recieve incoming midi data from the PC over the USB port, while it is being powered by the usb port?
Any tips suggestions or pointers would be greatly appreciated.
Thanks for reading.
I am using Windows 10
Thanks for reading.
