Teensy 4.0 fingerprint for eagle cad?
I'm looking for a Teensy 4.0 fingerprint for eagle cad. I do not require the "difficult" pins at the bottom.
Or is there a way for converting kicad automatically to eagle cad?
You can use the Teensy 3.2 in Eagle - should be the same.
But not the pin-out I think?
Senior Member+
Note: I don't do much with Eagle. I do have an older version(6.6.0 light), that I mainly use to translate files to diptrace format, which I use....
Yep - There are subtle changes, but my guess is, it would not be hard to go in and make a copy and rename a couple of pins and remove a few others...
That is more or less what I did with Diptrace.
- You may not post replies
- You may not edit your posts
Forum Rules
