Results 1 to 5 of 5
Thread: Arduino 1.8.10 & Teensyduino 1.49b3: no audio library yet?
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    125
    Just did a fresh install of Arduino 1.8.10 & Teensyduino 1.49b3.
    Selected Teensy 4.0. And then tried to select "Audio".
    Did I miss somehow that the Audio library is not yet supported on Teensy 4?
    Thanks,
    Paul
    6,091
    My guess that USB Audio output is not yet done...
    From the B2 release notes:
    Add Teensy 4.0 USB MIDI, Keyboard, Mouse, Joystick
    My guess is the port of the Audio stuff might be a little more complex.
    1,215
    The audio library is there but USB Audio isn't done yet.
    Pete
    21,302
    Yes, indeed. Isochronous rate feedback used for asynchronous mode audio uses a 3 byte format when running at 12 Mbit speed, and a different 4 byte format for 480 Mbit speed. Frame timing is also different, 1 ms at 12 Mbit versus 125 us at 480 Mbit.
    Currently all the existing USB audio code is written for the USB controller in the older chips and designed only for 12 Mbit speed.
    Apr 2015
    Netherlands
    125
    Thanks for the explanations! Yes, I can understand the USB complexity.
    Paul
