Results 1 to 5 of 5
Thread: CanBUS joystick
    Dec 2018
    3
    CanBUS joystick
    Hi guys, I have a project in mind for a couple years and I want to have advice if it's doable or not!
    I'm a simulator gamer and I want to build joystick's setup to play Farming/construction Simulator etc.
    Basically I'll want to buy 2 Joystick with can setup to reduce cabling and have the flexibility to do what I want just by reprogramming the controller.
    Can a teensy board will be able to make this project work and be recognize be the PC as a gamepad or input device.
    P. S. : I'm not a programmer at all, but I'm familiar with coding simple thing and can learn if I have a how to / documentation.
    Germany NRW
    6,163
    Yes you can do that. But why CAN?
    I'd chose a more simple protocol between the Joysticks.
    I think there is a joystick-example somewhere if you download Teensyduino.
    Dec 2018
    3
    Because for this type of joystick head I'll have a damn load of wire to route if I go the pot or hall sensor.
    https://images.app.goo.gl/mrVeqUZeJcEbpGGb8
    Germany NRW
    6,163
    There is a CANbus library somewhere, too, but I haven't used it.
    Quote Originally Posted by Boushard View Post
    How much does the joystick cost ? They look expensive.
Tags for this Thread
