Results 1 to 6 of 6
Thread: Teensy 4 probs with >1MB elfs
    Senior Member JarkkoL's Avatar
    Jul 2013
    112
    I have an issue with >1MB elfs on Teensy 4. If I have >1MB program running on T4 and I want to upload another elf, regardless of the size of the new elf, this upload always fails (gives "Download Error" in Teensy Loader). So I have to hit the "programming button" on T4 and recompile & reupload the program for it to work. I don't know if this is a known issue and it's not that big of a deal, more of an annoyance. Uploading works fine for <1MB elfs.
    Thanks, Jarkko
    10,922
    In that >1MB code does Serial In and out work? What version of TeensyDuino is in use?
    Perhaps a post of the Verbose Teensy Loader 'Verbose Info' log {under help} would show something?
    21,467
    My first guess is we may have a timing bug, where Teensy Loader might not be waiting long enough for the chip to erase when it's been previously programmed. I did test a full chip upload early in the T4 beta, but it's been a while since those tests.
    Can you please give me the .hex and .elf file you're uploading. This forum's advanced editor lets you attach a zip file to your message. Click the "Go Advanced" button if you're using the "Quick Reply" editor, to get the editor which lets you attach a file.
    Also, please tell me which operating system and version you're using, so I can be sure to test the same way you're uploading.
    Jul 2013
    112
    Had some problems trying to upload hex & elf, but attached is the project. I'm compiling on Win10 & Arduino IDE 1.8.10 (uploading via Visual Micro also fails), Teensyduino 1.48. This is also using the Audio Adaptor Board (Rev D).
    Attached Files Attached Files
    21,467
    Working on this now. Indeed, the problem is a 2.5 second timeout (in Teensy Loader) while waiting for chip erase. It's actually taking 2.8 seconds when previously programmed with this much data.
    There's also a bug where it should be displaying "Erasing..." in the progress bar, but changes too soon to "Programming".
    Soon I'll publish 1.49-beta4 with the timeout lengthened to 6 seconds, and that status display fixed.
    Jul 2013
    112
    Thanks for checking it out.
    Cheers, Jarkko
