Results 1 to 4 of 4
Thread: Any decent fonts for RA8875 display ?
    I'm using Sumotoy's RA8875 driver on a Teensy 4.0
    The display and driver works but I found the font is a bit strange.
    The aerial_22 and aerial_48 font doesn't look like Arial font and aerial_48 is upper case only.
    So is there a decent set of Arial fonts for the RA8875 ?
       display.setFont(&Liberation_Mono_72);
       display.setCursor(0, 0);
       display.println("Liberation_Mono_72");
       display.setFont(&Liberation_Mono_48);
       display.setCursor(0, 100);
       display.println("Liberation_Mono_48");
       display.setFont(&Liberation_Mono_36);
       display.setCursor(0, 150);
       display.println("Liberation_Mono_36");
       display.setFont(&Liberation_Mono_28);
       display.setCursor(0, 200);
       display.println("Liberation_Mono_28");
       display.setFont(&LiberationMono_24);
       display.setCursor(0, 230);
       display.println("LiberationMono_24");
       display.setFont(&aerial_22);
       display.setCursor(0, 300);
       display.println("aerial_22");
       display.setFont(&aerial_48);
       display.setCursor(0, 340);
       display.println("Testing 123 aerial_48");
    New York
    4,616
    Well never tried this but Sumotoy has a method to convert fonts: https://github.com/sumotoy/RA8875/wi...convert-a-font
    The other thing is that the adafruit version seems to support their fonts: https://forums.adafruit.com/viewtopic.php?t=96819 and https://forums.adafruit.com/viewtopic.php?t=124652 Guess will have to look at that.
    Just tried Sumotoy's font conversion tutorial. It works !!!
    Initially the converter software only listed the Arial font. I didn't really want to use that font because I believe it is copy righted.
    I downloaded the liberation font and installed in my Windows machine.
    https://github.com/liberationfonts/l...ses/tag/2.00.5
    Ran the converter software again and selected the liberation font. Generate the .c file and copy that into my Teensy project.
    New York
    4,616
    Good to know that it works, never tried it.
    Out of curiosity l did a quick test and looks like with some effort you could get the RA8875 to use Adafruit fonts, etc. Going to put it on to do list.
