Results 1 to 7 of 7
Thread: USB for T4.0
    2,530
    USB for T4.0
    Iīm struggling with the T4.0 USB implementation. I try to implement the MTPDISK feature, which I urgently need on T4.0.
    So, I try to learn from existing implementation.
    At the moment I fail to understand the following snippet
    int usb_rawhid_recv(void *buffer, uint32_t timeout)
    	uint32_t wait_begin_at = systick_millis_count;
    	while (1) {
    		if (!usb_configuration) return -1; // usb not enumerated by host
    		uint32_t status = usb_transfer_status(rx_transfer);
    		if (!(status & 0x80)) break; // transfer descriptor ready
    		if (systick_millis_count - wait_begin_at > timeout) return 0;
    		yield();
    	memcpy(buffer, rx_buffer, RAWHID_RX_SIZE);
    	memset(rx_transfer, 0, sizeof(rx_transfer));
    	usb_prepare_transfer(rx_transfer + 0, rx_buffer, RAWHID_RX_SIZE, 0);
    	usb_receive(RAWHID_RX_ENDPOINT, rx_transfer + 0);
    	return RAWHID_RX_SIZE;
    in particular, I do not understand the sequence
    which I thought should read
    Any clarification?
    Can someone confirm that RAWHID works for T4.0?
    Edit: Maybe because it is interrupt driven receive? Does bulk receive work at all?
    21,357
    Any clarification?
    usb_prepare_transfer() and usb_receive() set up for the next transfer which will happen at some point in the future, whenever the USB host decides to send another OUT token (or PING then OUT, if Teensy's controller answered the last OUT with a NYET token). The memcpy which gets the data from the just-completed transfer should be done before you set up another transfer. Odds are slim the USB will be fast enough to receive another transfer that fast (overwriting the previously received data before you can copy to the user's buffer), but why risk it?
    These very low level USB functions are all non-blocking. usb_transmit() also just sets up the transfer to happen at some point in the future, whenever the USB host controller decides to send an IN token.
    You later discover when the transfer has actually happened, either by polling or an interrupt context callback. You choose which way by giving usb_config_tx() and usb_config_rx() a function pointer in the 4th parameter if you want callbacks from that endpoint, or NULL if you intend to poll the status bit.
    It definitely works when we test the USB connection on every Teensy 4.0. The test fixture send RawHID messages to tell Teensy 4.0 (and every other Teensy model) to turn its LED on and off, and measures the change in current consumption. The code for that test fixture is published here:
    https://github.com/PaulStoffregen/USB_Tester
    2,530
    Thanks Paul.
    OK, so it is my work now to understand why I cannot get MTP to work.
    (I only run into timeout, but after 1 week playing, I may have something screwed up.)
    2,530
    Iīm now one step further.
    I cloned usb_rawhid into usb_mtp
    I configured usb_mtp with interrupt context callbacks.
    Not sure how to configure MTP_EVENTS (receive ore transmit, bulk or interrupt?)
    PC (windows10) created a MTP USB Device without warning sign.
    Unfortunately, PC only sends a Open Session command (0x1002; RX_Event fires) to which I respond with OK (TX event fires).
    after that no activity anymore on MTP_RX_ENDDPOINT.
    Only the ENDPOINT0 gets a 0x67A1 command, to which I (similar to Teensy3) answer with OK.
    Strange is that NO GetDeviceInfo cmd (0x1001) is received.
    Not sure what is going on
    Docu says GetDeviceInfo, may not be called if Device is known. Not sure is this is the case and how to check this.
    2,530
    update,
    by turning on Paulīs debug printf in usb.c I note that usb isr is called about 1/s with status bits USB_USBSTS_SRI and USB_USBSTS_TI0, which seems to be normal behaviour.
    USB is keep running as reprogram request (SEREMU Reboot request) is handled correctly.
    No clue yet how to get PC to ask for DeviceInfo and the rest of the disk info.
    2,530
    As I run out of ideas, I post the test program as zip file.
    Instructions are in Read_me.txt. If in doubt ask.
    Maybe someone has more luck and finds the solution to the puzzle.
    It should be clear that the MTP responder is not complete, as I only wanted to advance step-by-step and the first step is failing (no GetDeviceInfo request)
    for completeness, here is my initial printout
    ***********IMXRT Startup**********
    test 1 -1234567 3
    CCM_ANALOG_PLL_USB1=80003000
      enable USB clocks
    CCM_ANALOG_PLL_USB1=80003040
    need to switch to alternate clock during reconfigure of ARM PLL
    USB PLL is running, so we can use 120 MHz
    Freq: 12 MHz * 88 / 2 / 1
    ARM PLL=80002042
    ARM PLL needs reconfigure
    ARM PLL=80002058
    New Frequency: ARM=528000000, IPG=132000000
    BURSTSIZE=00000808
    BURSTSIZE=00000808
    USB1_TXFILLTUNING=00000000
    USB reset took 4 loops
    analogInit
    *suspend
    *reset
    *data 00000001
    setup 00000680
    complete 00000000
    port at 480 Mbit
    *data 00000001
    setup 00000500
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000900
    usb_seremu_configure
    usb_mtp_configure
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    **data 00000001
    setup 00000A21
    complete 00000000
    *data 00000001
    setup 00000681
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000680
    complete 00000000
    *data 00000001
    setup 00000080
    complete 00000000
    *data 00000000
    complete 00100008
    run_callbacks
    rx 1 3
    run_callbacks
    tx_event 1 4
    *data 00000000
    complete 00000000
    RX: 16 1 00001002 0 1
    TX: 16 3 00002001 0 1
    *data 00000000
    complete 00080000
    run_callbacks
    tx 1 3
    *****data 00000000
    complete 00140000
    run_callbacks
    tx_event 1 4
    ******data 00000000
    complete 00140000
    run_callbacks
    tx_event 1 4
    ******data 00000000
    complete 00140000
    run_callbacks
    tx_event 1 4
    ******data 00000000
    complete 00140000
    run_callbacks
    tx_event 1 4
    ******data 00000000
    complete 00140000
    run_callbacks
    tx_event 1 4
    ******data 00000000
    complete 00140000
    run_callbacks
    tx_event 1 4
    **data 00000001
    setup 000067A1
    0x67A1 000067A1
    complete 00000000
    etc. etc.
    In fact, there are two questions,
    why is GetDeviceInfo never called and why is sendEvent (every 5 seconds) not working?
    Attached Files Attached Files
    2,530
    A heads-up:
    Got USB_MTPDISK working on T4.
    As soon I have cleaned up SW and generated I library and further tests, I will post on MTP-Responder thread.
    I also will suggest to Paul (via PR) mods to core.
