Results 1 to 2 of 2
Thread: Random Numbers : Teensy 4.0 and Entropy Library
    Junior Member JupiterMoll's Avatar
    Nov 2019
    Berlin
    12
    Hallo,
    I,m trying to compile the example Seed_PRNG included in the Entropy library of Teensyduino for generating random Numbers with Teensy 4.0
    #include <Entropy.h>
    #define randomSeed(s) srandom(s)
      uint32_t seed_value;
      while (!Serial) {
      Entropy.initialize();
      seed_value = Entropy.random();
      Serial.print("Seed value = ");
      Serial.println(seed_value);
      randomSeed(seed_value);
    I got this error message during compiling:
    Arduino: 1.8.9 (Linux), TD: 1.48, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp: In member function 'void EntropyClass::initialize()':
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp:67:3: error: 'SIM_SCGC5' was not declared in this scope
       SIM_SCGC5 |= SIM_SCGC5_LPTIMER;
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp:67:16: error: 'SIM_SCGC5_LPTIMER' was not declared in this scope
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp:68:3: error: 'LPTMR0_CSR' was not declared in this scope
       LPTMR0_CSR = 0b10000100;
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp:69:3: error: 'LPTMR0_PSR' was not declared in this scope
       LPTMR0_PSR = 0b00000101;  // PCS=01 : 1 kHz clock
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp:70:3: error: 'LPTMR0_CMR' was not declared in this scope
       LPTMR0_CMR = 0x0006;      // smaller number = faster random numbers...
    In file included from /home/alphi/Downloads/arduino-1.8.9-linux64/arduino-1.8.9/hardware/teensy/avr/cores/teensy4/core_pins.h:32:0,
                     from /home/alphi/Downloads/arduino-1.8.9-linux64/arduino-1.8.9/hardware/teensy/avr/cores/teensy4/wiring.h:38,
                     from /home/alphi/Downloads/arduino-1.8.9-linux64/arduino-1.8.9/hardware/teensy/avr/cores/teensy4/WProgram.h:45,
                     from /tmp/arduino_build_981811/pch/Arduino.h:6:
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp:72:19: error: 'IRQ_LPTMR' was not declared in this scope
       NVIC_ENABLE_IRQ(IRQ_LPTMR);
    /home/alphi/Downloads/arduino-1.8.9-linux64/arduino-1.8.9/hardware/teensy/avr/cores/teensy4/imxrt.h:8296:52: note: in definition of macro 'NVIC_ENABLE_IRQ'
     #define NVIC_ENABLE_IRQ(n)      (*(&NVIC_ISER0 + ((n) >> 5)) = (1 << ((n) & 31)))
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp: In function 'void lptmr_isr()':
    /home/alphi/Arduino/libraries/Entropy/Entropy.cpp:336:3: error: 'LPTMR0_CSR' was not declared in this scope
    Multiple libraries were found for "Entropy.h"
     Used: /home/alphi/Arduino/libraries/Entropy
     Not used: /home/alphi/Downloads/arduino-1.8.9-linux64/arduino-1.8.9/hardware/teensy/avr/libraries/Entropy
    Using library Entropy in folder: /home/alphi/Arduino/libraries/Entropy (legacy)
    It seems that the Entropy Library is not compatible with Teensy 4.0.
    Is there a workarround to create random Numbers or can somebody help me to updated this library to work with Teensy 4.0 ???
    Thx...
    2,501
    entropy lib is based on "duelling clocks" and has not been ported to T4, but T3.5, T3.6, and T4.0 have hardware random number generators. The T4 generator is discussed in this thread:
    https://forum.pjrc.com/threads/54711...l=1#post195000
    It is slow compared to T3.5/3.6 TRNG.
    https://github.com/manitou48/teensy4...aster/trng.ino
    if you don't need crypto-strength random numbers, there is always random()
