WGSpacetime
I have multiple problems with my Teensy 4.0, which worked completely fine before. I don't know if they're connected with each other or not.
- My Teensy 4.0 disconnects itself from my laptop's USB after 30 to 90 seconds of connection. It works fine, and executes everything I program it too (disclaimer: I only tested digital and analog writes and reads), but if ofc makes debugging hell, as I can't receive data to the serial monitor for longer than approx. 90s from boot-up.
- My other computer doesn't even register that I connect Teensy 4.0. I checked all the wires, they are good (everything works with other boards). I also reset Teensy 4.0 to it's original state by pressing Reset button for 15 seconds.
- Teensy's processor gets pretty warm (35°C) even while executing simple script (like blinking builtin LED or sending PWM signal in one of the pins).
