Results 1 to 5 of 5
Thread: Clock speed for PDB: Tested on Teensy 3.2 and 3.5
    Jan 2020
    6
    Hi, as an introduction to PDB and DMA I was trying to work through the tutorial at https://courses.cs.washington.edu/co...abs/l5/l5.html and have written the Arduino blink sketch posted below. This works on both Teensy 3.2 and 3.5 selecting a CPU speed of 48 MHz from the "Tools" menu option. However, the LED does not blink at all at the higher clock speeds (e.g. 72 MHz, 96 MHz) and I do not understand why. Can someone explain why and help me find the solution?
    // PDB 0 Status and Control Register
    #define PDB_CONFIG (PDB_SC_TRGSEL(15) | PDB_SC_PDBEN | PDB_SC_PDBIE | PDB_SC_CONT | PDB_SC_PRESCALER(7) | PDB_SC_MULT(1))
    //(PDB_SC_TRGSEL(n)       //  B8-B11  Software trigger is selected
    //|PDB_SC_PDBEN           //  B7      PDB enable
    //|PDB_SC_PDBIE           //  B5      Interrupt enable
    //|PDB_SC_CONT            //  B1      Continuous mode
    //|PDB_SC_PRESCALER(n)    //  B12-B14 Counting uses peripheral clock divided by multiplication factor
    //|PDB_SC_MULT(1)     )   //  B2-B3   Prescaler multiplication factor = 10 (00=1,01=10,10=20,11=40)
    #define PDB_PERIOD 37500  // 1 Hz at 48 MHz clock speed
    pinMode(13, OUTPUT);
    GPIOC_PDDR |= (1 << 5);
    GPIOC_PCOR |= (1 << 5);
    // Enable PDB clock module in System Clock Gating Control Register 6
     SIM_SCGC6 |= SIM_SCGC6_PDB;
    // PDB 0 Modulus Register specifies the counter top value (resets to zero on reaching this value)
    // If the counter is in continuous mode, it will continue counting from 0
    // Set to 1/(48 MHz / 128 prescaler / 10) * 37500 = 1 s
     PDB0_MOD = PDB_PERIOD;  //1 = 9.36khz
     PDB0_IDLY = 0;             // Interrupt delay = 0
     PDB0_SC |= PDB_CONFIG;     // Set status and control register
     PDB0_SC |= PDB_SC_SWTRIG;  // Software trigger enable (reset and restart counter)
     PDB0_SC |= PDB_SC_LDOK;    // Load OK
     NVIC_ENABLE_IRQ(IRQ_PDB);  // Enable interrupt request
    void loop() {}
    void pdb_isr() {
       GPIOC_PTOR |= (1<<5); // toggle pin 13 each interrupt
       PDB0_SC = PDB_CONFIG | PDB_SC_LDOK; // (also clears interrupt flag)
    2,558
    try reordering the statements in the isr
    void pdb_isr() {
      GPIOC_PTOR |= (1 << 5); // toggle pin 13 each interrupt
    Also, note the PDB ticks at the speed of F_BUS. For F_CPU at 48mhz and 96mhz, F_BUS will be 48mhz, but for F_CPU@72mhz, F_BUS is 36mhz, so PDB_PERIOD may need adjusting. If you want the PDB period to be N ticks, you load N-1 in PDB0_MOD. PDB0_MOD is only 16 bits, so you have to adjust prescale and multiplier so that period "fits" in 16-bits.
    Jan 2020
    6
    @manitou, why would clearing the interrupt first matter?
    2,558
    if you count interrupts in the isr (cnt++) and print cnt every second in loop, you will see for your sketch at high CPU speed, it is counting 2 interrupts every second. isr is firing twice. If you reorder to clear the interrupt first thing in the isr, then that provides a delay for the interrupt flag to clear. Paul and others can probably provide a more accurate explanation. One could also spin-wait in the isr for the flag to be cleared in PDB0_SC
    Jan 2020
    6
    OK. Thanks! Much appreciated. I forgot to say that this made my program work, even 168 MHz CPU speed (overclock) option on Teensy 3.5.
Tags for this Thread
