Hi, as an introduction to PDB and DMA I was trying to work through the tutorial at https://courses.cs.washington.edu/courses/cse466/15au/labs/l5/l5.html and have written the Arduino blink sketch posted below. This works on both Teensy 3.2 and 3.5 selecting a CPU speed of 48 MHz from the "Tools" menu option. However, the LED does not blink at all at the higher clock speeds (e.g. 72 MHz, 96 MHz) and I do not understand why. Can someone explain why and help me find the solution?
// PDB 0 Status and Control Register
#define PDB_CONFIG (PDB_SC_TRGSEL(15) | PDB_SC_PDBEN | PDB_SC_PDBIE | PDB_SC_CONT | PDB_SC_PRESCALER(7) | PDB_SC_MULT(1))
//(PDB_SC_TRGSEL(n) // B8-B11 Software trigger is selected
//|PDB_SC_PDBEN // B7 PDB enable
//|PDB_SC_PDBIE // B5 Interrupt enable
//|PDB_SC_CONT // B1 Continuous mode
//|PDB_SC_PRESCALER(n) // B12-B14 Counting uses peripheral clock divided by multiplication factor
//|PDB_SC_MULT(1) ) // B2-B3 Prescaler multiplication factor = 10 (00=1,01=10,10=20,11=40)
#define PDB_PERIOD 37500 // 1 Hz at 48 MHz clock speed
pinMode(13, OUTPUT);
GPIOC_PDDR |= (1 << 5);
GPIOC_PCOR |= (1 << 5);
// Enable PDB clock module in System Clock Gating Control Register 6
SIM_SCGC6 |= SIM_SCGC6_PDB;
// PDB 0 Modulus Register specifies the counter top value (resets to zero on reaching this value)
// If the counter is in continuous mode, it will continue counting from 0
// Set to 1/(48 MHz / 128 prescaler / 10) * 37500 = 1 s
PDB0_MOD = PDB_PERIOD; //1 = 9.36khz
PDB0_IDLY = 0; // Interrupt delay = 0
PDB0_SC |= PDB_CONFIG; // Set status and control register
PDB0_SC |= PDB_SC_SWTRIG; // Software trigger enable (reset and restart counter)
PDB0_SC |= PDB_SC_LDOK; // Load OK
NVIC_ENABLE_IRQ(IRQ_PDB); // Enable interrupt request
void loop() {}
void pdb_isr() {
GPIOC_PTOR |= (1<<5); // toggle pin 13 each interrupt
PDB0_SC = PDB_CONFIG | PDB_SC_LDOK; // (also clears interrupt flag)
