Results 1 to 9 of 9
Thread: HELP - I have two Teensy's with same COM Port Number
    Aug 2018
    17
    I have a weird issue with my Teensy's 3.6. I have two different boards and when I plug the first board to the PC; it will show COM Port 20; if I unplug the first board to plug the second board; then the second board will show as COM Port 20 too (same as the first board). Also, the serial numbers are the same too!
    I haven't plug both boards at the same time. Any help will be appreciated.
    10,588
    Have either or both been programmed with a sketch from new? A sketch with USB Serial active? Even Blink?
    If the IDE and TeensyLoader are used to install even a blink sketch with USB Serial they should properly report and be recognized.
    Aug 2018
    17
    They are recognized. Both boards have been programmed with a sketch without any issues. The only issue I have is that both have the same com port & serial numbers. In theory, they should be unique (each one with different com ports)
    21,302
    Where did you buy these Teensy 3.6 boards?
    Aug 2018
    17
    I bought them from you directly. I bought a couple of the MKL02 from your store to create my own teensy 3.6
    10,588
    Quote Originally Posted by mendez View Post
    Interesting - that is quite right - they should be unique once they are ID'D. PJRC has process in place to assign unique Serial #'s.
    Not seen this before on Windows - don't know OS in use? IDE and Teensyduino version ?
    Some code could print the serial # from within a sketch (forum has links or steal it from the PJRC core). Looked the other day and TeensyLoader Verbose doesn't seem to expose a device Serial#.
    With TyCommander (search Forum) installed it will present a UI with info about the COM port and Serial#
    Perhaps another computer or rebooting this one.
    One other thing might be to try the eat-3.6's 15 second Restore in turn plug each in start a timer with running second count: Hold Program button as 15 seconds pass and release. If anything unsettled the Teensy that will put the chip back to proper factory state - except there will not be any active sketch - and no USB presentation to PC - until reprogrammed.
    10,588
    This cross-posted while sleeping on the last post. Any self made will not have a unique Serial # until burned into the MCU area. Mixing and matching may confuse the PC.
    21,302
    Yup, custom made boards will have a blank serial number (all 1s) in the MK66's "program once" memory. Easiest thing to do is edit usb_desc.c and put your own number into the code.
    The serial number is *NOT* stored in the MKL02 chip.
    Windows uses the serial number the distinguish between physical hardware and associate the COM port number.
    Aug 2018
    17
    Oh OK, makes sense! Thanks. So, is there a way to assign a unique serial number automatically for mass produced boards? Or do I need to edit usb_desc.c each time I load a firmware to the board?
    I will look into editing usb_desc.c
    Thanks again!
