I'm running this display on a T4 that I am using interrupts on for timing events, etc.. When using the tft.updateScreen(); function, the amount of time it takes to process is far too long for the system to work properly. At max, I have pulses coming into an interrupt that are only 0.002s apart.
When not using frame buffering, the system works just fine but there is so much flickering on the screen that it becomes nearly impossible to even read the text I'm displaying.
I also have a chunk of data spewing out of the serial port which does not negatively affect it's operation.. Same info I'm trying to display on the TFT, in fact... Just text, no graphic files at all. I have also tried using the latest ILI9341_T3 library by Paul but it has the same flickering problem and it doesn't have a framebuffer, at least not that I Am aware of..
Here is my code for the setup.. The section where I Am sending a few lines of text to the display are a little below half way through the code...
Hopefully someone can shed some light here...
#include "SPI.h"
#include "ILI9341_t3n.h"
#include "ili9341_t3n_font_Arial.h"
#include "ili9341_t3n_font_OpenSans.h"
#include "ili9341_t3n_font_ArialBold.h"
#include "ili9341_t3n_font_ComicSansMS.h"
#define TFT_DC 9
#define TFT_CS 10
//#define TFT_RST 8
ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC);
#define HRES 320
#define VRES 240
#define REF1 14
#define REF2 15
#define POS1 16
#define MAP 17
#define ETS 7
#define TPS 0
#define IGN1 18
#define IGN2 19
#define IGN3 20
#define IGN4 21
#define IGN5 22
#define IGN6 23
#define INJ1 1
#define INJ2 2
#define INJ3 3
#define INJ4 4
#define INJ5 5
#define INJ6 6
volatile float REFRise;
volatile float REFRiseOld;
volatile float REFFall;
volatile float RPM = 1;
volatile bool CycleInterval = false;
volatile float REFHigh;
volatile bool IGNChk = false;
volatile float FiringTime;
float REFRiseChk;
float DwellTime = 5000; // in us
long DwellAngle;
float RPMNew;
int CylNo = 0;
int CylNoInj = 0;
float TimePerDegree;
float DTI;
int timingAdvance = 35;
bool IgnWait = false;
bool InjWait = false;
bool Sync = false;
float DTInj;
long Cycles;
float WatchDog1;
float WatchDog2;
volatile int POSDeg = 0;
float InjectionTime;
volatile int ScreenUpdate = 100;
volatile long ScreenTimer1;
volatile long ScreenTimer2;
volatile long ManPres;
volatile long TPSVolt;
volatile int EngTemp = 70;
tft.begin();
tft.setTextColor(ILI9341_YELLOW);
tft.setRotation(1);
tft.useFrameBuffer(0);
pinMode(IGN1, OUTPUT);
pinMode(IGN2, OUTPUT);
pinMode(IGN3, OUTPUT);
pinMode(IGN4, OUTPUT);
pinMode(IGN5, OUTPUT);
pinMode(IGN6, OUTPUT);
pinMode(INJ1, OUTPUT);
pinMode(INJ2, OUTPUT);
pinMode(INJ3, OUTPUT);
pinMode(INJ4, OUTPUT);
pinMode(INJ5, OUTPUT);
pinMode(INJ6, OUTPUT);
pinMode(REF1, INPUT_PULLUP);
pinMode(REF2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(REF1), REFRISE, RISING);
attachInterrupt(digitalPinToInterrupt(REF2), REFFALL, FALLING);
attachInterrupt(digitalPinToInterrupt(POS1), POSRISE, RISING);
tft.setFont (Arial_18_Bold);
WatchDog1 += 1;
if (WatchDog1 >= 5000000) {
Sync = false;
Halt();
Cycles += 1;
if (CycleInterval == true) {
WatchDog1 = 0;
CylNo += 1;
if (CylNo == 7) {
CylNo = 1;
REFHigh = REFFall - REFRise;
RPM = 60000000 / (REFRiseOld * 3);
TimePerDegree = (RPM / 60);
TimePerDegree *= 360;
TimePerDegree = (1000000 / TimePerDegree);
REFHigh /= TimePerDegree;
DTI = TimePerDegree * (112 - timingAdvance);
DTI += REFRise;
IgnWait = true;
InjWait = true;
if (Sync == false) {
if (REFHigh >= 2 && REFHigh <= 10){
CylNo = 1;
if (REFHigh >= 43 && REFHigh <= 55){
CylNo = 2;
if (REFHigh >= 36 && REFHigh <= 40){
CylNo = 3;
if (REFHigh >= 28 && REFHigh <= 34){
CylNo = 4;
if (REFHigh >= 21 && REFHigh <= 26){
CylNo = 5;
if (REFHigh >= 12 && REFHigh <= 19){
CylNo = 6;
Sync = true;
detachInterrupt(digitalPinToInterrupt(POS1));
CylNoInj = CylNo - 1;
if (CylNoInj == 0) {
CylNoInj = 6;
InjectionTime = 2234 / RPM;
DTInj = (InjectionTime * 1000) + micros();
digitalWrite(CylNoInj, HIGH);
Serial.print("Engine RPM: ");
Serial.print(RPM);
Serial.print("Cylinder In Compression Stroke: ");
Serial.print(CylNo);
Serial.print("Delay Time Interval to next ignition event: ");
Serial.print(DTI - micros());
Serial.println(" us");
Serial.print("Timing Check: ");
Serial.print(((FiringTime - REFRiseChk) / TimePerDegree) - 112);
Serial.println(" BTDC");
Serial.print("Cylinder ");
Serial.print(CylNoInj);
Serial.println(" is starting fuel injection cycle.");
Serial.print("Fuel Injector Pulse Duration: ");
Serial.print(InjectionTime);
Serial.println(" ms");
Serial.print("REFHigh: ");
Serial.print(REFHigh);
Serial.print("Time Per Degree: ");
Serial.print(TimePerDegree);
Serial.println(Cycles);
Serial.print("POS Degrees: ");
Serial.println(POSDeg);
IGNChk = false;
tft.setCursor(10,10);
//tft.fillRect(55,0,200,120,ILI9341_BLACK);
tft.print("RPM: ");
tft.print(RPM);
tft.setCursor(10, 30);
tft.print("MAP: ");
tft.print(ManPres);
tft.setCursor(10, 50);
tft.print("TPS: ");
tft.print(TPSVolt);
//tft.updateScreen();
if (IgnWait == true && DTI <= micros()){
FiringTime = micros();
digitalWrite((CylNo + 17), HIGH);
delayMicroseconds(DwellTime / 50);
digitalWrite((CylNo + 17), LOW);
REFRiseChk = REFRise;
IgnWait = false;
IGNChk = false;
if (InjWait == true && DTInj <= micros()){
digitalWrite(CylNoInj, LOW);
InjWait = false;
void Halt() {
digitalWrite(18, LOW);
digitalWrite(19, LOW);
digitalWrite(20, LOW);
digitalWrite(21, LOW);
digitalWrite(22, LOW);
digitalWrite(23, LOW);
digitalWrite(1, LOW);
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
void REFRISE() {
REFRiseOld = micros() - REFRise;
REFRise = micros();
IGNChk = true;
WatchDog1 = 0;
void REFFALL() {
REFFall = micros();
CycleInterval = true;
WatchDog1 = 0;
ManPres = analogRead(MAP);
TPSVolt = analogRead(TPS);
EngTemp = analogRead(ETS);
void POSRISE() {
POSDeg += 1;
