Results 1 to 18 of 18
Thread: Teensy 3.5 with Audio Board rev B - not work
    Jan 2020
    8
    hi.
    I bought teensy 3.5 & AB rev B.
    I don't remember, why not rev C, but have B.
    Without AB teensy connect to PC, can Upload scetch.
    After soldering board together, it stop work, no sound on lineOut/headphones, not upload.
    it's compatible? or need magic cut of some pins?
    if detach AB from teensy, controller work correctly.
    soryy for my english.
    Thanks.
    Germany NRW
    6,218
    Please post a photo.
    Jan 2020
    8
    Germany NRW
    6,218
    At a first glance, this looks OK.
    Have you tried to upload the blink-sketch? Does it work?
    Germany NRW
    6,218
    Hm, does the 3v3 pin has contact? It's difficult to see.
    Jan 2020
    8
    trouble on this time next - can't upload sceth after solder AB. not see COM port when plug to USB. I think - have conflicts when i connect AB and teensy not work correct. Can we try solve this first?
    This solder is second time. After first, i detach AB and upload come back. But i use headphone for sound and led not light (i think, what board not work, as Arduino board have led light when work).
    Germany NRW
    6,218
    2,527
    Quote Originally Posted by mr_ebox View Post
    Led (pin13) does not work when using Audioboard.
    Audioboard does not work when using pinMode(13,OUTPUT) in setup.
    Jan 2020
    8
    all i try.
    teensy window uploader not see board not in auto mode, not after press button.
    in list of devices on PC not change in HID, port, USB ...
    Germany NRW
    6,218
    Have you tried the 15 seconds reset?
    https://forum.pjrc.com/threads/37531...l=1#post116941
    If that does not work, too.. your Teensy may be dead.
    Germany NRW
    6,218
    As last chance, look for shorts, excessive solder..
    ..and try to cut all pins and remove the Audio Shield.
    Jan 2020
    8
    ok.
    i try remove.
    main? rev B can work with 3.5?
    2,527
    yes, Rev B works with all T3.x
    Rev D ONLY works with T4.0
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    533
    try resoldering every single solder joint under magnification and carefully check every solder joint under magnification glasses.
    In the photos you can see several weak or faulty solder joints, for example pin 2 is NOT connected and others seem suspect (for example the pin on the Audio shield left of the SD card holder).
    Jan 2020
    8
    bad news.
    i take new 3.6 upload to "simpleDrum" - "blink" - "simpleDrum" - it's ok.
    Next, i solder pins on both board and connect wires without solder.
    Connect to USB - PC write Unknown Device, sounds no on Line out...
    After, i detach boards, and try upload sketch. Nothing. RESET 15 sec not help.
    I upload so many Arduino Nano (2$) ~ 30 pcs with add components as microphone, button, relays - all work of all time.
    First teensy's have trouble on start...
    Really such an unreliable board?
    I'm very sad...
    ~70$ (2 teensy, 2 AudioShield, shipping) fly to black hole...
    Jan 2020
    8
    hmmm...
    i don't understand...
    While i types previous post ... sketh uploads ....
    3.6 wake up...
    How it work?
    need more power?
    21,332
    I can also confirm, Rev B definitely does work with Teensy 3.5.
    Rev C added a 100 ohm resistor. The 100 ohm resistor is only needed if long wires (length of a solderless breadboard) are used with Teensy 3.6, or any length wires are used with Teensy 4.0 (but keeping the wires very short is difficult because Rec B & C have the I2S signals in the wrong pins for direct use with Teensy 4.0).
    Rev B works with Teensy 3.5 even if long wires are used.
    Even the incompatible cases, like using Rev D on Teensy 3.x or Rev B & C on Teensy 4.0 (without re-routing the I2S wires) do not cause Teensy to fail at USB communication. Again, any rev audio shield used with Teensy 3.5 should not cause USB problems. If USB communication is disrupted, that's a sure sign something worse is going on.
    Jan 2020
    8
    some unknown.
    first upload Simple drum no hear...
    more time.
    I change on PlaySynthMsic - it's hear
    After start play and Drum...
    Mystic
