SPI0 and SPI1/2
Forgive the potential daft question, but I'm trying to use two different SPI ports on a Teensy 4.0
I have done some searching but can't see how to do this.
I've got SPI0 working (default SPI port, great), but I'd like to use a second SPI port (TX only), I've soldered wires onto the underside of my teensy 4.0 for both SPI1 and SPI2.
I'm not planning on using the SDCard.
Is there a library that will allow me to do this?
Senior Member+
Typically, instead of using SPI.<whatever>, you would use SPI1.<whatever> or SPI2.<whatever>.
Now, whether the higher level libraries, support different SPI buses depends on the library.
Oh, thanks, that was min numbingly easy
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
