TeensyTimerTool
... then everything works correctly, but I don't want to use Delay()
You can use elapsedMillis instead:
elapsedMillis stopwatch;
   if(stopwatch > 500)
      Serial7.print("IF;");
      Serial7.flush();
      stopwatch-=500;
BTW: why don't you want to use delay?
   if(stopwatch > 500)
      Serial7.flush();
      stopwatch-=500;
thank you! I will try to do so,
I have many other tasks in the code, I would not like to delay them ..
Hello dear.
please tell the beginner again,
how to implement such an algorithm ?
Thanks in advance for your help !
Timer1 = 15 ms
Timer2 = 25 ms
if (Condition 1)
Timer1 ON
Executable code 1
Timer1 OFF
if (Condition 2)
Timer2 ON
Executable code 2
Timer2 OFF
I need a 40 kHz pulse train so I used a timer at 12.5 us and toggled the output on and off, but the PeriodicTimer only uses integer microseconds. I searched this forum for "submicrosecond" and "nanosecond" and did not find hits.
I was using a Teensy 3.2, but switched to a 4.0. Using the TeensyTimerTool I am able to get a stable eight pulse train - but at 12 us half period instead of 12.5 us.
Ahhh. So inside my isr I could delay 500 ns? A hack.
So I could calculate the extra nanoseconds I need and store it in a global volatile int, and the isr could delay that many ns. (I hate coding for a fixed frequency and having a "magic" number buried in an isr.)
Thanks for the idea!
The following should generate 8 pulses at 40kHz on a T3.2 using the the first of the 8 FTM0 hardware timers.
#include "Arduino.h"
#include "TeensyTimerTool.h"
using namespace TeensyTimerTool;
PeriodicTimer timer(FTM0);
void pulse()
    static unsigned cnt = 0;
    if (cnt++ < 16)
        digitalToggleFast(0);
        timer.stop();
    pinMode(0, OUTPUT);
    timer.begin(pulse, 2 * 40_kHz);
How precise do you need your 40kHz? At the standard CPU clock of 96MHz the FTMs are clocked with 48MHz. If you set the CPU clock to 120MHz you get a bus clock of 60MHz which fits better to your 40Khz requirement (-> reload value = 750). I also suggest to set the counter prescaler to the smallest value to get a better resolution (see here https://github.com/luni64/TeensyTimerTool/wiki/Configuration how to do this)
Just saw that you switched to a T4. The only thing you need to change in the code above is to use TMR4 instead of FTM0. Reducing the prescaler is also suggested. I.e., change it from PSC_128 to PSC_1 in line 46 of the config file.
Here a LA trace for the T4.0 using the code from above (with TMR4 instead of FTM0)
Is it safe to use a delay function in an ISR?
Normally, yes.
But if you've increased your interrupt's priority level to beyond 32 (lower numbers mean higher priority), then no.
Most interrupts default to priority 128, in the middle of the 0-255 range. The timing stuff defaults to 32 (nearly the highest priority), so it's usable from most other interrupts. But we never configure any of the core library or main Teensyduino libraries to use higher priority than 32 (numbers 31 or less) for people who need their interrupt to work in at the highest priority.
Apparently only for Teensy 4.X.
Maybe you have an old version. In Arduino, click Help > About to check.
Teensyduino 1.54 brought delayNanoseconds() to all Teensy models, even Teensy 2.0. Obviously at only 16 MHz, the nanosecond resolution isn't as good, but it is implemented as well as AVR can do.
Jumped Threads
void pulse()
    if (cnt++ < 16)
        timer.stop();
    pinMode(0, OUTPUT);
I changed loop to repeat the pulse train with a delay of 100 ms.
  cnt = 0;
where cnt is a global volatile.
With a Teensy 3.2 I get about 2.5 us jitter in the length of the whole pulse train, 1.25 %. (NOT the rep rate. I trigger my scope on the leading edge of the pulse train.)
With a Teensy 4.0, changing the timer to GPT1 I can't see any jitter on a 250 ns/cm scale.
I am making an ultrasonic anemometer so that jitter limits my windspeed resolution to about 1.2% of the sound speed, or about 4 m/s. I need about 0.5 m/s to 0.1 m/s accuracy.
I would like to stay with the Teensy 3.2 because I have a bunch of them, and for the power consumption.
BTW, I posted here with a question about TeensyTimerTool that was spawned from a different thread, so see https://forum.pjrc.com/threads/68040-How-to-Make-a-Pulse-Train-of-Exactly-N-pulses for the bigger discussion.
Try delayMicroseconds(100 * 1000);
if that does not help, you may have to use an additional timer(which is preferable anyway)
I.e. an intervalTimer
The problem is NOT in the repetition rate. The total length of a single train of 8 pulses jitters by 2.5 us. In the other thread I took a suggestion and tried the IntervalTimer. Much better results. 50 ns jitter in the length of the pulse train and a frequency of 39.8 kHz which is closer to 40 kHz than I could get with the TeensyTimerTool.
The FTMs are a bit tricky since the 8 channels share one timer. In the ISR the TimerTool adds the channel reload value to the current counter which of course takes some time so that the actual period is not super accurate.
The GPTs have one timer per channel (as do the TMRs and PITs) -> periods are as precise as the timer is.
Generally, if you have such high performance requirements a canned, general purpuse library may not be the best choice. If you need to stick with the T3.2 I'd use the PITs and optimize the reload value.
Anyway, the jitter can be reduced by increasing the priority of the FTMs. Here some code to show this and to measure the jitter.
volatile uint32_t cnt = 0;
volatile bool run     = false;
volatile uint32_t dt  = 0;
void pulse()
    static uint32_t t0 = 0;
    if (cnt == 0)
        t0  = ARM_DWT_CYCCNT;
    if (cnt++ < 16)
        dt = ARM_DWT_CYCCNT - t0;
        timer.stop();
        run = false;
        cnt = 0;
    pinMode(0, OUTPUT);
    ARM_DEMCR |= ARM_DEMCR_TRCENA;          // enable debug/trace
    ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA; // enable cycle counter
    timer.begin(pulse, 12.0f, false);  // experimentally optimize frequency since FTMs share one timer for the channels
    NVIC_SET_PRIORITY(IRQ_FTM0, 1);   // higher priority to reduce jitter
    run = true;
    timer.start();             // start the timer
    while (run == true) {}     // wait until done
    Serial.println(dt/96.0f);  // print time for complete sequence in µs
This prints (microseconds)
200.59
200.89
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.60
200.84
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.72
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.60
200.59
200.64
200.59
200.59
201.01
200.64
200.59
200.59
201.01
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.60
200.59
200.59
200.64
200.59
201.01
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.60
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.61
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
201.01
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.89
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.72
200.59
200.59
200.59
200.68
200.59
200.59
200.59
200.68
200.59
200.59
200.59
200.68
201.01
200.59
200.59
200.68
200.76
200.59
200.59
200.68
200.76
200.59
200.59
200.68
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.60
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
201.01
200.59
200.59
200.59
201.01
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.61
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
201.01
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.60
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.80
200.64
200.59
200.59
200.76
200.64
200.60
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.76
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
201.01
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.76
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
201.01
200.59
200.59
200.64
200.76
200.60
200.59
200.64
200.76
200.59
200.59
200.64
200.80
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.89
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.76
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
201.01
200.59
200.59
200.59
201.01
200.59
200.59
200.59
200.76
200.60
200.59
200.59
200.76
200.59
200.59
200.59
200.93
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.59
200.59
200.59
200.64
200.60
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
200.59
201.01
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.93
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.76
200.59
200.59
200.59
200.59
200.59
200.59
Here the jitter analysis:
And here the pulse train
Edit: BTW you should use the newest version of the library (0.3.5). While doing your examples I found some glitches wich are fixed...
Just for fun, a very quickly hacked version using a PIT directly. This gives rock solid 40kHz pulses and no jitter. Let me know if you need explanations...
IntervalTimer timer;
KINETISK_PIT_CHANNEL_t* channel;
void pulse();
void init()
    timer.begin(pulse, 100);                            // get an interval timer
    int n          = (IRQ_NUMBER_t)timer - IRQ_PIT_CH0; // old trick to get hold of the used channel
    channel        = KINETISK_PIT_CHANNELS + n;
    channel->TCTRL = 0;       // stop the timer
    channel->LDVAL = 600 - 1; // set to 40 kHz
void start()
    channel->TCTRL = PIT_TCTRL_TEN | PIT_TCTRL_TIE;
void stop()
    channel->TCTRL = 0;
void pulse()
    if (cnt++ < 16)
        stop();
        run = false;
        cnt = 0;
    pinMode(0, OUTPUT);
    init();
    run = true;
...first, awesome work/library! But in addition to trigger some actions based on some accurate timing I need some time measurement based on pin level changes. Do I missed something or is a simple running timer which I can ask for the time while pin level changed missing ? Besides the general elapsedMicros or elapsedMillis ...
TeensyTimerTool v0.4.1
There is a new release (v0.4.1) of the TimerTool: https://github.com/luni64/TeensyTimerTool/releases
Main new features:
  • Destructors should work now -> you can define your timer locally. Leaving the scope will gracefully shut down the timer and release allocated hardware resoruces (...hopefully)
  • setPeriod and setNextPeriod should work for most timers now (PIT, TMR, GPT, TCKxx) . Both functions will change the period of a running timer. setPeriod tries to do this immediately (which only works if the new period is longer than the old one or the request comes early enough), setNextPeriod will do the change after the current period is done. Both functions also accept std::chrono time literals e.g. setPeriod(2.2s) or setNextPeriod(14534ns) etc.
  • I added a new 64 bit software timer (TCK_RTC) which is based on the built in RTC instead of the cycle counter. This might be useful if the callbacks need to be synced to the RTC.
    Here an example printing the drift between the 32.768kHz RTC crystal and the 24MHz main crystal:
    PeriodicTimer t1(TCK_RTC);
    constexpr uint32_t period = 500'000; //µs
    void callback()
        static uint32_t start = micros();
        static uint32_t idx   = 0;
        uint32_t now          = micros() - start;
        uint32_t expected     = idx++ * period;
        int32_t delta         = now - expected;
        float drift           = 1E6 * delta / expected;  // ppm
        Serial.printf("t: %d µs,  rel. drift: %.2f ppm\n", now, drift);
    void setup(){
        t1.begin(callback, period);
    void loop(){
    output:
    t: 17500023 µs,  rel. drift: 1.31 ppm
    t: 18000024 µs,  rel. drift: 1.33 ppm
    t: 18500025 µs,  rel. drift: 1.35 ppm
    t: 19000025 µs,  rel. drift: 1.32 ppm
    t: 19500026 µs,  rel. drift: 1.33 ppm
    t: 20000027 µs,  rel. drift: 1.35 ppm
    t: 20500027 µs,  rel. drift: 1.32 ppm
    t: 21000028 µs,  rel. drift: 1.33 ppm
    t: 21500029 µs,  rel. drift: 1.35 ppm
    t: 22000030 µs,  rel. drift: 1.36 ppm
    t: 22500030 µs,  rel. drift: 1.33 ppm
DMA based Pulse Generator for T4.x boards
I added an alpha version of a DMA based pulse generator to the TimerTool (it lives in the PulseGenerator branch). Currently, it only works on the pins which can be driven by the TMR / QUAD timers. I.e., pins 10,11,12,13,14,15,18,19. I'll try to add the other pins (FlexPWM based) later, in case the whole thing turns out to be useful at all. (My final goal is to use DMA based pulse generation in TeensyStep, to avoid using resource- hungry timer interrupts for step pulse generation).
Here examples how to use it and what can be done. The first example shows how to use compile time defined pulse sequences. You can enter the times using the std::chrono literals (ns, us, ms, s,..) or plain numbers (float), which are interpreted as microseconds. (BTW: conversion from chrono literals to (float)microseconds is always done at compile time. I.e., without runtime penalty)
PulseGenerator pulseGenerator;
// define a pulse train {{high,low},{high,low},....}
PulseTrain train_1{{2ms, 3ms}, {1ms, 3ms}, {50us, 3ms}, {1000, 3000}, {2000, 3000}}; // numbers without units are interpreted as us (microseconds)
// another pulse train
PulseTrain train_2{{300ns, 2us}, {300ns, 3us}, {50ns, 3us}, {300ns, 2us}, {300ns, 2us}};
void setup(){
    pulseGenerator.begin(10); // attach the pulse generator to pin 10
void loop(){
    pulseGenerator.trigger(train_1);    // select one or both pulse trains
    //pulseGenerator.trigger(train_2);
    //delay(100);
train_1:
train_2:
The following example shows how to construct a pulse train at run time which probably is a more interesting use case:
    // generate a simple acceleration/decleration pattern at runtime
    // e.g. a stepper motor ramp
    Pulse pulses[200];
    for (int i = 0; i < 100; i++)
        pulses[i].hi = 500ns;
        pulses[i].lo = 2us + 500ns * i;
        pulses[i + 100].hi = pulses[99 - i].hi;
        pulses[i + 100].lo = pulses[99 - i].lo;
    PulseTrain stepperTrain(pulses, sizeof(pulses)/sizeof(pulses[0])); // use the array to construct a PulseTrain
    pulseGenerator.trigger(stepperTrain); // trigger the pulse train.
void loop(){
As mentioned the pulse generation is done loading reload values from a buffer to the timer using DMA. I didn't do any measurements so far but it should not generate significant load on the processor. As far as my cheap LA can measure, pulses below 50ns seem to be possible. Ultimately the minimal pulse width is limited by the time the DMA channel needs to copy new compare values to the timer hardware.
Let me know if this is of any use, if any additional features are needed to be useful etc. Extending to circular buffers, or other DMA schemes should be not too difficult. Using the other pins might be more demanding (I don't have any experience with the FlexPWM timers).
Hello Lutz,
today I had some time to share and I decided to update TeensyTimerTool library is some of my projects. For most of them I upgraded from 0.2.1 to 0.4.1.
In one of them I had a problem with "isnan()" which don't operate now. If I switch back to 0.2.1 there is no problem. I use visualTeensy and VScode for most of my projects.
Here is the VScode error :
'isnan' was not declared in this scope
and here is the compilation error message :
src/main.cpp:2239:37: error: 'isnan' was not declared in this scope
   if (isnan((*item).RA->getAverage()))
src/main.cpp:2239:37: note: suggested alternative:
In file included from lib/TeensyTimerTool/src/API/baseTimer.h:12:0,
                 from lib/TeensyTimerTool/src/API/oneShotTimer.h:4,
                 from lib/TeensyTimerTool/src/TeensyTimerTool.h:3,
                 from src/main.h:19,
                 from src/main.cpp:9:
c:\progra~2\arduino\hardware\tools\arm\arm-none-eabi\include\c++\5.4.1\cmath:641:5: note:   'std::isnan'
     isnan(_Tp __x)
make: *** [makefile:232: .vsteensy/build/src/main.cpp.o] Error 1
Hope (sure) you can solve the problem.
Thank you,
Manu
