Page 8 of 11 FirstFirst ... 6 7 8 9 10 ... LastLast
Results 176 to 200 of 261
Thread: TeensyTimerTool
  1. #176
    1,369
    So that you can #define the YIELD_TYPE before you include the library.
    This pattern only works if you can make sure that all translation units have the define before including the header. The TeensyTimerTool supports project scope config files instead. See here https://github.com/luni64/TeensyTime.../Configuration for instructions
  2. #177
    Apr 2020
    Germany, NRW
    86
    Ok, thanks, i will have a look.
  3. #178
    Jan 2015
    France
    135
    This is due to the new yield code in the beta. I'll fix that the next days. If you need an urgent solution and if you do not need SerialEvents or the EventResponder you can set the yield type to YIELD_OPTIMIZED. See here: https://github.com/luni64/TeensyTime...yield-settings for instructions.
    Thank you.
    I'm not in hurry with this. It was just a feedback.
    Manu
  4. #179
    1,369
    Fixed by using the EventResponder to tick the software timers in YIELD_STANDARD mode. This is slightly less efficient than the old version but there always is YIELD_OPTIMIZED mode if you need high efficiency of the software timers. (See here https://forum.pjrc.com/threads/60333...l=1#post243706 for an explanation of the new yield strategy)
    @Manu: would be great if you could give it a quick try (v0.1.10)
  5. #180
    Jan 2015
    France
    135
    Hello Luni,
    Thank you for this quick fix. I just downloaded the last release (v0.1.10) and it compile without error. Unfortunately my last project which use Teensy 4.x is at it very beginning and, while I know I'll use TeensyTimerTool, I haven't any current code which use it.
    Anyway, I tested the new release with a teensy 3.2 project and it operate very well.
    Thank you,
    Manu
  6. #181
    @luni:
    What is correct way if I want to stop timer for time being?
      myTimer.begin(TimerFunction,10'000); // 10ms
    This used to init timer.
    I tried this to stop this timer but not working out. what is correct way to stop this timer?
    myTimer.end(); //Timer Ends here.
  7. #182
    8,464
    I have not played with this for awhile, but my guess would be to do: myTimer.stop();
    Which is defined in baseTimer... But again just a guess.
  8. #183
    1,369
    Valid guess, but actually this currently is only implemented for the TCK timers. The others silently ignore it. I'm currently working on filling in some missing functionality... As a workaround you can meanwhile simply call begin with a nullpointer as callback. This will effectively stop the timer.
  9. #184
    Thanks luni,
    myTimer.begin([]{int (*pfun) (void) = NULL;},10'000); // 10ms
    worked out.
  10. #185
    1,369
    Yes that works, but your code is a bit complicated. You probably noticed that passing a nullptr as function argument compiles but doesn't work since the library catches this as error. So, instead of passing a nullptr you need to pass an empty function:
    #include "TeensyTimerTool.h"
    using namespace TeensyTimerTool;
    void empty() {}  // empty function
    PeriodicTimer t1;
        pinMode(13, OUTPUT);
        t1.begin([] { digitalWriteFast(13, !digitalReadFast(13)); }, 75'000); //Blink
        delay(3000);
        t1.begin(empty, 50'000); //stop timer
    Or if you prefer lambdas you can define the empty function inline:
    PeriodicTimer t1;
        delay(3000);
        t1.begin([]{}, 50'000); //stop timer
    void loop(){}
  11. #186
    Yes,
    I tried with empty function as well. That code I shared also worked. Got it I think the one you suggested looks better.
  12. #187
    1,369
    Quote Originally Posted by HallMark View Post
    @luni:
    I just added the missing start/stop functionality for the TCK, TMR(QUAD), GPT and PIT timers to the TeensyTimerTool v0.1.11. See here for details and download https://github.com/luni64/TeensyTimerTool/releases
    Quick usage example:
    PeriodicTimer t1;
        while (!Serial) {}
        TeensyTimerTool::attachErrFunc(ErrorHandler(Serial)); // optional, print errors on Serial
        t1.begin([] { digitalToggleFast(13); }, 50'000); //Blink
        delay(2000);  // stop timer after 2s
        t1.stop();
        delay(2000);  // restart after 2s
        t1.start();
    Now working on a possibility to chain the TMR timers to get 16 / 32 / 48 and 64 bit wide timers.
  13. #188
    Great ! I just realize I am using too old version for this lib. I am using 0.1.7 version. Updating now and going to test this out.
  14. #189
    1,369
    IIRC you are using the FTM timers. Forgot to add them in v0.1.11, just pushed v0.1.12 which should work for the FTMs as well
  15. #190
    Jan 2015
    France
    135
    Imcompatibility with ILI9341_T3
    Hello Luni
    I found an incompatibility between TeensyTimerTool and Paul's ILI9341_t3.
    When one want to use both libraries in the same sketch, compiler can't complete and throw errors.
    Here is a sample of code that illustrate this :
    #include "SPI.h"
    #include "ILI9341_t3.h"
    #include "XPT2046_Touchscreen.h"
    // #include "CAN_T3.h"
    #define RefreshScreenPeriod 100   // 100 millisecondes
    PeriodicTimer AfficherInfo(TCK);
    void timerRefreshScreen() {
      Serial.println("timer Tick");
      Serial.begin (115200);
      while ((!Serial) && (millis() < 750));
      AfficherInfo.begin(timerRefreshScreen, RefreshScreenPeriod * 1000);
    If you comment the "#include "ILI9341_t3.h" it compile. If not, it don't compile.
    Thank you.
    Manu
  16. #191
    1,369
    Which board are you using?
  17. #192
    Jan 2015
    France
    135
    teensy 3.2
  18. #193
    1,369
    It looks like ILI9341_t3 defines a macro "swap" which clashes with standard c++ headers (<functional> in this case). You can work around by including the ILI9341_t3.h after TeensyTimerTool.h. I can not test if it really works but at least it compiles then.
  19. #194
    Jan 2015
    France
    135
    Thank you,
    I'll try and let you know
  20. #195
    1,369
    I opened a corresponding issue in the ILI9341_t3 repo https://github.com/PaulStoffregen/ILI9341_t3/issues/62
  21. #196
    Jan 2015
    France
    135
    I confirm that including TeensyTimerTool before other libraries work.
    However, I think there is a bug with FTM timers and Teensy 3.2 (72Mhz - compile as Faster).
    When I use this as a periodic timer for 100ms, the result is a timer around 57 to 60ms.
    Using the exact same code, but with TCK timer give a robust 100ms without a miss or deviation.
    I tested this with a simple
    PeriodicTimer AfficherInfo(FTM0);
      Serial.println(millis());
  22. #197
    1,369
    Good, maybe the maintainers of the ILI lib are willing to fix the issue. On the other hand, the workaround is quite simple...
    No, this is to be expected. The FTMs are 16bit timers and, at standard settings will overflow at about 56ms. TeensyTimerTool detects this, issues a warning and sets the period to the max possible value. You can either check the return value of "begin" or, more easy, activate the built in error handler by adding this line to your setup()
    The library will then print any error to Serial (or whichever stream object you pass to the ErrorHandler constructor). This is quite useful during development. Here the output of your sketch with activated error handler:
    W-100: Period overflow, set to maximum
    421
    465
    509
    552
    596
    640
    683
    727
    771
    814
    858
    See here https://github.com/luni64/TeensyTime...Error-Handling for a documentation of the error handling capabilities of the library.
    If you need longer periods than the standard ~50ms you can change the prescaler of the FTM timer in the config file. See here https://github.com/luni64/TeensyTime.../Configuration for a documentation of this feature.
  23. #198
    Jan 2015
    France
    135
    Thank you for this explanation.
  24. #199
    8,464
    Obviously any of us can create a PR to fix this... So I went ahead and did it:
    https://github.com/PaulStoffregen/ILI9341_t3/pull/63
  25. #200
    1,369
    Thanks a lot Kurt! I didn't want to create this PR since I can only check if the change compiles but have no means of testing the functionality.
