PT8215, cheap I2S A/D
Frank B
Only by chance (a typo) I found the counterpart to our "darling" PT8211: The PT8215.
I myself have, I think, little use for it. But it would certainly be interesting to support this part in the audio library.
I haven't found a source of supply for it yet, so I haven't ordered it yet. But I will certainly order and write code to support it when I have found a dealer.
Here is a short data sheet: https://pdf1.alldatasheet.com/datasheet-pdf/view/35173/PTC/PT8215-S.html if anyone is interested.
Are you sure it's an A/D.
Here's the datasheet I was able to download. Says "16 Bits Digital-to-Analog Converter IC". Looks like same as PT2811, but with voltage reference on pin 7.
  • pt2815.pdf
Damn, no.
It was a few days back when i saw it.. it must have a different part number.
Ok.. closing here.. sry.
