Results 1 to 3 of 3
Thread: Do any of the audio library synths work with teensy LC
    Hi
    I have had a good look through the forums and can't find an answer. Do any of the audio library synths work with Teensy LC and it's DAC?
    I can't get my code to compile (it's a sine wave played through the dac)
    My Code
    AudioSynthWaveformSine   sine1;          //xy=205,179
    AudioOutputAnalog        dac1;           //xy=424,189
    AudioConnection          patchCord1(sine1, dac1);
    AudioMemory(10); // Dynamic memory is allocated to be used exclusively by the Audio library
    sine1.frequency(12000);
    sine1.amplitude(0.85);
    The error messages don't seem to help
    would this be indicating an issue - that it's using core teensy3?
    Using board 'teensyLC' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
    Using core 'teensy3' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr
    otherwise the only issues I am having coming up in red are the following
     Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
     Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
    Error compiling for board Teensy LC.
    Is it possible to play around with audio on the Teensy LC without shields? we have a heap and were hoping to use them for a small audio workshop
    - Would there be other ways to make sound I can look up?
    full verbose log is here
    Arduino: 1.8.5 (Mac OS X), TD: 1.46, Board: "Teensy LC, Serial, 48 MHz, Smallest Code, US English"
    /Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/tarapattenden/Documents/Arduino/libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=osstd,keys=en-us -ide-version=10805 -build-path /var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517 -warnings=none -build-cache /var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_cache_829123 -verbose /Users/tarapattenden/Documents/Arduino-old/test-teensylc/test-teensylc.ino
    /Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/tarapattenden/Documents/Arduino/libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=osstd,keys=en-us -ide-version=10805 -build-path /var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517 -warnings=none -build-cache /var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_cache_829123 -verbose /Users/tarapattenden/Documents/Arduino-old/test-teensylc/test-teensylc.ino
    Detecting libraries used...
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft1024.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft256.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_notefreq.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_peak.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_print.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_rms.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_tonedetect.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_ak4558.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_cs42448.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_cs4272.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_sgtl5000.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_tlv320aic3206.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_wm8731.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_spdif.c" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_ulaw.c" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_waveforms.c" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_windows.c" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_bitcrusher.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_chorus.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_combine.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_delay.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_delay_ext.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_envelope.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_fade.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_flange.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_freeverb.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_granular.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_multiply.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_reverb.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_waveshaper.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_biquad.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_fir.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_variable.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adc.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adcs.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s2.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_i2s_quad.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_pdm.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_tdm.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_tdm2.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/memcpy_audio.S" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/mixer.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_adat.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_dac.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_dacs.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s2.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_i2s_quad.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_mqs.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pt8211.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pt8211_2.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_pwm.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif2.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_spdif3.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_tdm.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/output_tdm2.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_memory.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_queue.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_sd_raw.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_sd_wav.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_serialflash_raw.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/record_queue.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/spi_interrupt.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_dc.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_karplusstrong.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_pinknoise.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_pwm.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_simple_drum.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_sine.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_tonesweep.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_waveform.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_wavetable.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/synth_whitenoise.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility/imxrt_hw.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility/sqrt_integer.c" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI/SPI.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/File.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/SD.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/cache_t3.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/card_t3.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/dir_t3.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/fat_t3.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/file_t3.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/init_t3.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/KinetisSDHC.c" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/NXP_SDHC.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/Sd2Card.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/SdFile.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/SdVolume.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash/SerialFlashChip.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash/SerialFlashDirectory.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/Wire.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireIMXRT.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireKinetis.cpp" -o "/dev/null"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/utility/twi.c" -o "/dev/null"
    Generating function prototypes...
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/preproc/ctags_target_for_gcc_minus_e.cpp"
    "/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/preproc/ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/precompile_helper" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517" "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch/Arduino.h" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch/Arduino.h.gch"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/sketch/test-teensylc.ino.cpp.o"
    Compiling libraries...
    Compiling library "Audio"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/memcpy_audio.S" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/memcpy_audio.S.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_spdif.c" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/data_spdif.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_ulaw.c" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/data_ulaw.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_waveforms.c" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/data_waveforms.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/data_windows.c" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/data_windows.c.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft1024.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/analyze_fft1024.cpp.o"
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft1024.cpp:34:13: warning: 'void copy_to_fft_buffer(void*, const void*)' defined but not used [-Wunused-function]
     static void copy_to_fft_buffer(void *destination, const void *source)
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft1024.cpp:44:13: warning: 'void apply_window_to_fft_buffer(void*, const void*)' defined but not used [-Wunused-function]
     static void apply_window_to_fft_buffer(void *buffer, const void *window)
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft256.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/analyze_fft256.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_notefreq.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/analyze_notefreq.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_peak.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/analyze_peak.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_print.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/analyze_print.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_rms.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/analyze_rms.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_tonedetect.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/analyze_tonedetect.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_ak4558.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/control_ak4558.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_cs42448.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/control_cs42448.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_cs4272.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/control_cs4272.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_sgtl5000.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/control_sgtl5000.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_tlv320aic3206.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/control_tlv320aic3206.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/control_wm8731.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/control_wm8731.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_bitcrusher.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_bitcrusher.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_chorus.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_chorus.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_combine.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_combine.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_delay.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_delay.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_delay_ext.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_delay_ext.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_envelope.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_envelope.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_fade.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_fade.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_flange.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_flange.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_freeverb.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_freeverb.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_granular.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_granular.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_midside.cpp.o"
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp: In member function 'virtual void AudioEffectMidSide::update()':
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp:34:12: warning: unused variable 'pa' [-Wunused-variable]
      uint32_t *pa, *pb, *end;
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp:34:17: warning: unused variable 'pb' [-Wunused-variable]
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp:34:22: warning: unused variable 'end' [-Wunused-variable]
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp:35:11: warning: unused variable 'a12' [-Wunused-variable]
      uint32_t a12, a34; //, a56, a78;
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp:35:16: warning: unused variable 'a34' [-Wunused-variable]
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp:36:11: warning: unused variable 'b12' [-Wunused-variable]
      uint32_t b12, b34; //, b56, b78;
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_midside.cpp:36:16: warning: unused variable 'b34' [-Wunused-variable]
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_multiply.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_multiply.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_reverb.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_reverb.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/effect_waveshaper.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/effect_waveshaper.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_biquad.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/filter_biquad.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_fir.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/filter_fir.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/filter_variable.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/filter_variable.cpp.o"
    "/Applications/Arduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=146 -DARDUINO=10805 -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-I/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/pch" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire" "-I/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/utility" "/Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adc.cpp" -o "/var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T/arduino_build_839517/libraries/Audio/input_adc.cpp.o"
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adc.cpp: In static member function 'static void AudioInputAnalog::isr()':
    /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/input_adc.cpp:119:2: warning: 'daddr' is used uninitialized in this function [-Wuninitialized]
      if (daddr < (uint32_t)analog_rx_buffer + sizeof(analog_rx_buffer) / 2) {
    /var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T//ccU5UGs9.s: Assembler messages:
    /var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T//ccU5UGs9.s:291: Error: selected processor does not support `smull r0,ip,r3,r5' in Thumb mode
    /var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T//ccU5UGs9.s:292: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `mov ip,ip,asl r6'
    /var/folders/0c/8xvrqfyj38z97c0_mgn08fdr0000gn/T//ccU5UGs9.s:293: Error: unshifted register required -- `orr r0,ip,r0,lsr r7'
     Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
     Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
    Using library Audio at version 1.3 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio
    Using library SPI at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI
    Using library SD at version 1.2.2 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
    Using library SerialFlash at version 0.5 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SerialFlash
    Using library Wire at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire
    Error compiling for board Teensy LC.
    Thanks!
    21,860
    No, the audio library does not support Teensy LC at all.
    Senior Member JarkkoL's Avatar
    Jul 2013
    116
    Quote Originally Posted by phantomchips View Post
    - Would there be other ways to make sound I can look up?
    You could try Arduino Music Player to play music on LC.
