Results 1 to 12 of 12
Thread: T3.6 + audio board glitching at AUDIO_BLOCK_SAMPLES 64
    Oct 2016
    182
    Hi, I'm testing my T3.6 and audio adaptor board (rev C) but I have a lot of glitching and digital click if the AUDIO_BLOCK_SAMPLES is set to 64, at 128 works fine.
    It's possibile to solve? It's more important to have a less audio_block for me because the audio editing is more fast and responsive.. (low latency).
    Thank u
    Dani
    Member houtson's Avatar
    Aug 2015
    Scotland
    52
    Hi Dani, what audio objects are you using? I'm using a number of different objects with AUDIO_BLOCK_SAMPLES at 16 for the same reason (low latency) and all running well, Cheers Paul
    Oct 2016
    182
    Quote Originally Posted by houtson View Post
    nothing, I'm testing a code without audio objects and I have the same problem... on macOS Catalina.
    AudioInputUSB            usb1;           //xy=156,88
    AudioOutputUSB           usb2;           //xy=1128,88
    AudioOutputI2S           i2s1;           //xy=1154,165
    AudioConnection          patchCord1(usb1, 0, usb2, 0);
    AudioConnection          patchCord2(usb1, 0, i2s1, 0);
    AudioConnection          patchCord3(usb1, 1, usb2, 1);
    AudioConnection          patchCord4(usb1, 1, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=255,232
    void setup(void) {
    sgtl5000_1.enable();
    AudioMemory(80);
    sgtl5000_1.lineOutLevel(13);
    sgtl5000_1.lineInLevel(0);
    sgtl5000_1.adcHighPassFilterDisable();
    sgtl5000_1.muteHeadphone();
    void loop(void) {
    Oct 2016
    182
    I can confirm that the problem is present on macOS only, in Windows (7 in my test) all works fine!
    Any suggestion?
    Thank u
    Aug 2015
    Scotland
    52
    Hi danixdj,
    I don't have a great amount of USB experience but I have a mac and have looked out a 3.6 - how have you set up/connected the mac and where are you hearing the distortion (headphone on the audio board or through the mac) and I will try to replicate the issue.
    There was an earlier issue with usb and mac but I believe it was fixed and not related to sample block size.
    Oct 2016
    182
    Hi danixdj,
    I know but it's fixed now... and it's a different problem..
    Let me know
    Thank u
    Aug 2015
    Scotland
    52
    Oct 2016
    182
    The glitches and digital clip are always present and more evidence by headphone and speaker ..
    Aug 2015
    Scotland
    52
    Tried on a couple of different macOS versions with the same issue as you (glitches at AUDIO_SAMPLE BLOCK 64), nothing obvious /easy mades a difference. Block size lower than 64 sounds worse.
    Oct 2016
    182
    Someone can help us?
    21,466
    Don't suppose you can just set the block size back to 128?
    Many parts of the audio library automatically adapt to different block sizes. But some parts definitely depend on 128 samples. USB audio is one of those parts! If you use those parts which aren't compatible with other block sizes, there is no easy solution. The code depends on 128. The only fix would involve rewriting that audio lib code.
    Oct 2016
    182
    44.100 and 128 have a terrible latency for a good use in a real time audio process so 64 is acceptable but 128 it's impossible to use..
