WGSpacetime
I can't get BMP280 to work with my Teensy 3.5. I tried Adafruit BMP280 Library, BMP280_DEV, BMx280MI, I2C-Sensor-Lib.
Connections:
BMP280 -> Teensy 3.5
GND -> GND
VCC -> 3.3V
SCL -> 19
SDA -> 18
Excluding few diodes with appropriate resistors and SD card inserted to Teensy's built-in port there's nothing else connected to Teensy 3.5.
None of the mentioned libraries sees BMP280, and I'm not talking about my code, I'm talking about example codes that go with those libraries (this is also why I'm not posting code, I haven't written any, I just tested example sketched and they don't work). Are those libraries incompatible with Teensy 3.5, if yes, what should I use? Or should I assume my BMP280 is dead (it's brand new)? Perhaps there's something else
Connections:
GND -> GND
VCC -> 3.3V
SCL -> 19
SDA -> 18
