Results 1 to 8 of 8
Thread: Faster way to do if() compares in ISR?
    I'm working on a Teensy 3.2 I2C Sniffer project, and I have an ISR that triggers every 1 uSec using Timer1. I have instrumented the ISR with 'digitalWriteFast()' calls so that I can monitor activity on an O'scope. Here's the code:
        Created:	1/15/2020 8:30:09 AM
        Author:     FRANKNEWXPS15\Frank
    #include <TimerOne.h> //needed for ISR
    const uint16_t CAPTURE_ARRAY_SIZE = 2048;
    uint8_t raw_data[CAPTURE_ARRAY_SIZE]; //holds data captured from I2C bus
    #define MONITOR_OUT1 2 //so can monitor ISR activity with O'scope
    #define MONITOR_OUT2 3 //so can monitor ISR activity with O'scope
    #define MONITOR_OUT3 4 //so can monitor ISR activity with O'scope
    #define SDA_PIN 18
    #define SCL_PIN 19
    #pragma region ISR_SUPPORT
    volatile uint16_t  write_idx = 0;
    //volatile uint16_t  BurstLength = 0;
    volatile uint8_t   current_portb = 0xFF;
    volatile uint8_t   last_portb = 0xFF;
    #pragma endregion ISR Support
    volatile bool bDone = false;
    volatile bool bWaitingForStart = true;
    volatile bool bIsData = true;
    volatile bool bIsStart = false;
    volatile bool bIsStop = false;
    //volatile bool bFirstTime = true;
        unsigned long now = millis();
        Serial.begin(1); //rate value ignored
        int idx = 0;
        while (!Serial && (millis() - now) < 3000)
            idx++;
        Serial.printf("Serial available after %lu mSec\n", millis() - now);
        pinMode(MONITOR_OUT1, OUTPUT);
        digitalWrite(MONITOR_OUT1, LOW);
        pinMode(MONITOR_OUT2, OUTPUT);
        digitalWrite(MONITOR_OUT2, LOW);
        pinMode(MONITOR_OUT3, OUTPUT);
        digitalWrite(MONITOR_OUT3, LOW);
        pinMode(SCL_PIN, INPUT);
        pinMode(SDA_PIN, INPUT);
        //reset port byte vars & start timer
        last_portb = current_portb = 0;
        write_idx = 0;
        memset(raw_data, 255, CAPTURE_ARRAY_SIZE);
        PrintNextArrayBytes(raw_data, 255, 20);
        Timer1.initialize(1); // run every mico second
        Timer1.attachInterrupt(capture_data);
    //--------------------------------    ISR    ------------------------------------
    void capture_data()
        //digitalWriteFast(MONITOR_OUT1, HIGH);
        last_portb = current_portb;
        current_portb = GPIOB_PDIR & 12; //reads state of SDA (18) & SCL (19) at same time
        if (!bDone && last_portb != current_portb)
            //01/16/20 experiment
            bIsStart = last_portb == 0xC && current_portb == 0x4;
            bIsStop = last_portb == 0x4 && current_portb == 0xC;
            bIsData = (last_portb == 0x0 && current_portb == 0x4) || (last_portb == 0x8 && current_portb == 0xC);
            if (bIsStart) //START
                digitalWriteFast(MONITOR_OUT2, HIGH);
                if (bWaitingForStart)
                    raw_data[write_idx++] = last_portb; //capture the first byte
                    bWaitingForStart = false;
            else if (bIsStop) //STOP
                digitalWriteFast(MONITOR_OUT2, LOW);
            if (!bWaitingForStart && ( bIsData || bIsStart || bIsStop))
                digitalWriteFast(MONITOR_OUT3, HIGH);
                raw_data[write_idx] = last_portb;
                write_idx++;
                raw_data[write_idx] = current_portb;
                write_idx++;
                if (write_idx >= CAPTURE_ARRAY_SIZE)
                    //bDone = true;
                    write_idx = 0;
                digitalWriteFast(MONITOR_OUT3, LOW);
            digitalWriteFast(MONITOR_OUT1, LOW);
        //digitalWriteFast(MONITOR_OUT1, LOW);
    //-------------------------------- END ISR    ---------------------------------
        if (bDone)
            PrintNextArrayBytes(raw_data, 0, 150);
            while (true)
    void PrintNextArrayBytes(uint8_t* data, uint16_t startidx, uint16_t numbytes)
        Serial.printf("%d bytes starting at %d: ", numbytes, startidx);
        for (uint16_t i = 0; i < numbytes; i++)
            Serial.printf("%x\n", data[i + startidx]);
        Serial.printf("%x\n", data[numbytes + startidx - 1]);
    If I include the three compares shown here:
    Then the ISR takes about 1.4 uSec to complete, too long by 0.4 uSec or so. If I remove the compares, the time required to complete drops to about 0.425 uSec.
    If necessary, I can make everything work without the compares, but including them makes post-capture processing a lot easier. Is there a way to do the compares in a way that doesn't take so much time, other than going to a Teensy 3.6 or a T4?
    TIA,
    Frank
    You can reduce the number of comparisons from 8 to 4 by combining the two portb values into one variable
    uint8_t last_current = (last_portb << 4) | (current_portb);
    bIsStart = (last_current==0xC4);
    bIsStop = (last_current==0x4C);
    bIsData = (last_current==0x04) || (last_current==0x8C);
    and it's probably a little faster to avoid unnecessary comparisons and assignments. I didn't review your code to see when these values are set to false.
    if (last_current==0xC4)
    bIsStart = true;
    else if (last_current==0x4C)
    bIsStop = true;
    else if (last_current==0x04)
    bIsData = true;
    else if (last_current==0x8C)
    bIsData = true;
    Joe
    Joe,
    Thanks for the quick reply - that's a great idea combining the two values into the same 8-bit word! Your first suggestion,
    got the time down to around 1.2 uSec - a nice improvement, but not quite enough. And the other option you described,
    bIsStart = true;
    bIsStop = true;
    bIsData = true;
    bIsData = true;
    Is actually slower than my original code, clocking in at around 1.7 uSec.
    Frank
    Oct 2019
    Germany Maintal
    19
    Try to make it with:
    Switch last_current
    And remove the variables blsStart ...
    Do you need the first byte twice?
    Try removing "volatile" from those variable definitions.
    10,918
    Not sure what current code looks like ...
    If the _isr() did this stop() on end then bDone test is not needed at top of _isr() :: if (!bDone && last_portb != current_portb)
                    Timer1.stop();
                    bDone = true;
                    // write_idx = 0; // not needed
    bDone could be repurposed, and loop() could see when it was done.
    Only bDone would need to be volatile as nothing else in the _isr() is used outside the _isr() while it may be changing.
    Might help to do :: FASTRUN void capture_data()
    Defragster,
    wow - FASTRUN did the trick; went from 1.45 uSec to 0.89 uSec - thanks!
    If anyone ever had any doubts about the value of Paul's forum, this thread shows it; I had never heard of FASTRUN before this post. A few quick Google searches, and BAM - I'm an expert! ;-).
    Frank
    10,918
    Awesome - glad I was reading and thought to mention it and it made such a dramatic difference! I've spent the last year with the T4 beta to release and it runs code from RAM by default.
    Just read the other post and blog :: Teensy-I2C-Sniffer-for-MPU6050- nice work getting it done.
