Results 1 to 5 of 5
Thread: [queued] hatsune miku cosplay based on teensy 3.6
    Jan 2020
    4
    Hello
    just a little topic to share with you this cosplay project for my friend.
    she ask to try to make an original hatsune miku for the #mikuexpo2020 show in paris.
    I'm trained to work with arduino and far before to use 8051 based microcontroller (the one used in my robot build in 1999 and winner of the E=M6 french contest). but the arduino ram and speed limitation is a problem when driving lot of WS2812 pixels and color TFT + oled.
    so I've learn to use the teensy board and here are some pictures of the project
    first is the original design to realize:
    it's a "vocaloid" from yamaha and designed based on DX100 and DX7 keyboards
    so I've designed a bezel and front overlay based on the DX100 front panel
    and a light bezel for the leds
    the electronic board
    final test
    on the arm
    the headset design
ID:	18779   Click image for larger version.
ID:	18781   Click image for larger version.
ID:	18783   Click image for larger version.
    Jan 2020
    4
    and the end (I've made the post short
    the squares on the head
    and the final test: the event ^ ^
    and a short movie of the test
    http://thequark.free.fr/miku_cosplay/test.m4v
    Jan 2020
    4
    woops sorry
    I've just this this section was for project submission on the blog.
    This thread was to show how I've built the system around the teensy.
    My bad
    May 2018
    111
    Great job!
    Jan 2020
    4
    thank you
    lot of work but the final result is great
