Results 1 to 5 of 5
Thread: HID Keyboard Device has no Power Management Option
    Nov 2019
    19
    I want to use Teensy 4.0 programmed as HID keyboard for PC wakeup.
    But I do not see Power Management tab in Device Properties, while usual PC USB Keyboard has this tab.
    So, I could not wakeup PC with Teensy.
    I could not find any differences between Teensy HID Keyboard and ordinary usb keyboard in the Details tab.
    The question is: what is nessesary to activate Power Management tab for Teensy?
    Not sure if this will help, but here's an old thread that you can check out:
    I woke my Mac from sleep with a teensy 3.0
    Nov 2019
    19
    Thanks, daperl
    Setting
    0xA0 or 0xE0 // bmAttributes
    definitelly enables Power Management Option
    but it is not enough.
    USB0_CTL and USB_CTL_RESUME
    are not defined for T4
    Yeah, the control register names seem to be different for T4. But it seems clear from page 2344 of the RT1060 manual that you should be able to resume a connected USB host. Good luck.
    Nov 2019
    19
    Found a trivial solution:
    https://www.ftdichip.com/Support/Kno...motewakeup.htm
    works even with FT232RL
