i'm working in a project and i need to create a led matrix panel, powered with a powerbank (2V max 5A), controlled with smartphone via bluetooth.
first i tried to make it with addressable leds but their absorbe is high, then i serched a lot online and finally i find what i need, a 64x64 pixels led panel powered with a powerbank and there is an app to control it via WIFI!
the problem is that the app and the software of the panel are not open source, that's a problem to modify it.
the control board is this
the pins look similar at HUB75
Is it possible to change the control board of the panel with a esp32 or teensy?
have you any advise how to control it?
