Results 1 to 5 of 5
Thread: Accessing 128 bit sample packets
    Dec 2019
    6
    Hi all,
    I'm working on a university senior design team to implement an acoustic feedback cancellation device using the teensy4.0 and audio shield. At this point we'd like to use the CMSIS-DSP library, which has an easy to use normalized lms adaptive filter.
    We've successfully got our teensy 4.0 modules up and running processing audio, but need to close the gap between the under-the-hood operations of the audio library, and the CMSIS-DSP library.
    Our main challenge at this point is figuring out how to access the packets of data that stream between teensy audio objects. It's very easy to use the audio library with other audio library objects, but is there a way to store these packets to a buffer instead of sending straight to another processing or output object? If this is possible, we could "intercept" the packets with our normalized LMS filter, do some processing, and then send it to the audio output object.
    The code below is just a basic sketch that passes audio between the line-in and line-out.
    #include <SerialFlash.h>
    AudioInputI2S i2s_in;
    AudioOutputI2S i2s_out;
    AudioConnection patchcord1(i2s_in,0,i2s_out,0);
    AudioConnection patchcord2(i2s_in,0,i2s_out,1);
    AudioControlSGTL5000 sgtl5000;
    AudioMemory(10);
    sgtl5000.enable();
    sgtl5000.volume(0.5);
    Serial.print("Setup Complete \n");
    Serial.print("Streaming audio \n");
    1,217
    Have a look at the play and record "queue" objects in the audio library.
    Pete
    1,217
    Here's a simple use of the play and record queue objects. By default it plays stereo audio from line input to output (headphones). If a button is pushed, it simply swaps the left and right channels.
    It was tested on a T3.6 and on a T4.
    Pete
    // Tested on a T3.6 using pin 32 for the button
    // On T4 it uses pin 0
    // Simple demo of the use of record and play queues
    // If a button is pressed, switch the L and R channels
    // of the audio. Otherwise, play straight through.
    // By Pete El_Supremo 200119
    // Use this define to test that audio is playing
    // Then undefine it to test the channel switching
    //#define STRAIGHT_THRU
    #ifdef STRAIGHT_THRU
    AudioConnection          patchCord1(i2s_in, 0, i2s_out, 0);
    AudioConnection          patchCord2(i2s_in, 1, i2s_out, 1);
    #else
    AudioInputI2S            i2s_in;         //xy=357.8833312988281,290
    AudioRecordQueue         Q_in_L;         //xy=533.8833312988281,215.88333129882812
    AudioRecordQueue         Q_in_R;         //xy=538.8833312988281,341.8833312988281
    AudioPlayQueue           Q_out_L;         //xy=681.8833312988281,217.88333129882812
    AudioPlayQueue           Q_out_R;         //xy=682.8833312988281,338.8833312988281
    AudioOutputI2S           i2s_out;        //xy=837.88330078125,276
    AudioConnection          patchCord1(i2s_in, 0, Q_in_L, 0);
    AudioConnection          patchCord2(i2s_in, 1, Q_in_R, 0);
    AudioConnection          patchCord3(Q_out_L, 0, i2s_out, 0);
    AudioConnection          patchCord4(Q_out_R, 0, i2s_out, 1);
    AudioControlSGTL5000     sgtl5000;       //xy=452.8833312988281,423
    // Choose MICrophone or LINEIN
    //const int myInput = AUDIO_INPUT_MIC;
    short buf_L[AUDIO_BLOCK_SAMPLES];
    short buf_R[AUDIO_BLOCK_SAMPLES];
    // Button uses pin 32 on T3.6
    //#define SWITCH_PIN 32
    // Button uses pin 0 on T4
    #define SWITCH_PIN 0
    // debounce the button
    #include <Bounce.h>
    Bounce bouncer = Bounce( SWITCH_PIN,5 );
    void setup(void)
      pinMode(SWITCH_PIN,INPUT_PULLUP);
      // Audio connections require memory. and the record queue
      AudioMemory(10);
      // Enable the audio shield. select input. and enable output
      sgtl5000.enable();
      sgtl5000.inputSelect(myInput);
    #ifndef STRAIGHT_THRU
      // Start the record queues
      Q_in_L.begin();
      Q_in_R.begin();
    void loop(void)
      short *bp_L, *bp_R;
    // Update the debouncer
      bouncer.update();
    // When a left and right input buffer are available
    // process them both
      if (Q_in_L.available() >= 1 && Q_in_R.available() >= 1) {
        bp_L = Q_in_L.readBuffer();
        bp_R = Q_in_R.readBuffer();
        // Copy the audio buffers to our memory
        for(int i = 0; i < AUDIO_BLOCK_SAMPLES; i++) {
          buf_L[i] = bp_L[i];
          buf_R[i] = bp_R[i];
        // Free the input audio buffers
        Q_in_L.freeBuffer();
        Q_in_R.freeBuffer();
        // Process the buffers - if needed.
        // in this case - nothing to do
        if(bouncer.read()) {
          // Get pointers to "empty" output buffers
          bp_L = Q_out_L.getBuffer();
          bp_R = Q_out_R.getBuffer();
          // but switch them around
          bp_L = Q_out_R.getBuffer();
          bp_R = Q_out_L.getBuffer();
        // copy the (un)processed data back to the output
          bp_L[i] = buf_L[i];
          bp_R[i] = buf_R[i];
        // and play them back into the audio queues
        Q_out_L.playBuffer();
        Q_out_R.playBuffer();
    Dec 2019
    6
    Pete
    #else
    #include <Bounce.h>
    void setup(void)
      AudioMemory(10);
      sgtl5000.enable();
      Q_in_L.begin();
      Q_in_R.begin();
    void loop(void)
      short *bp_L, *bp_R;
      bouncer.update();
          buf_L[i] = bp_L[i];
          buf_R[i] = bp_R[i];
          bp_L[i] = buf_L[i];
          bp_R[i] = buf_R[i];
    Pete,
    I can't thank you enough! Being new to all this sometimes it's difficult to know where to begin looking. AudioRecordQueue and AudioPlayQueue will totally do the trick.
    1,217
    I know that feeling
    Glad to be of help.
    Pete
