Results 1 to 8 of 8
Thread: Teensy LC - Is it possible to save to permanent Memory?
    This is a curiosity question and my searches provided no results - though they could be out there.
    Anyway what I am thinking and the question is can something be saved in the process of the program that will be retained after power cycling.
    For Example - I want to permanently calibrate an Analog Axis. So I set up a button to press and while pressed then the program reads the DAC to get an upper endpoint number.. The Teensy then would Save this number permanently in itself to to be used as the upper limit of the analog axis..
    I know this can be done in the normal memory so it will be retained as long as the power is NOT turned off to the Teensy but is there any way to Permanently save it for access after a Power Cycle.
    Thank you,
    Aug 2018
    Brisbane, Australia
    8
    Germany NRW
    6,222
    You can use the eeprom library.
    https://www.pjrc.com/teensy/td_libs_EEPROM.html
    Edit.. lol, crosspost, thebigg was faster
    Thank you, Don't know HOW I missed that looking through all the information...
    21,338
    In Arduino, click File > Examples > EEPROM to open the examples which show how to use it.
    Thank you as well, I noticed the reference to that on the page that the other posted.
    Use a FRAM
    Quote Originally Posted by Brion Sohn View Post
    I us a 32 kb FRAM for this purpose.
    See https://www.adafruit.com/product/1895
    Germany NRW
    6,222
    Or just a sd card, if the inbuilt eeprom is not enough.
