Teensy LC - Is it possible to save to permanent Memory?
Brion Sohn
This is a curiosity question and my searches provided no results - though they could be out there.
Anyway what I am thinking and the question is can something be saved in the process of the program that will be retained after power cycling.
For Example - I want to permanently calibrate an Analog Axis. So I set up a button to press and while pressed then the program reads the DAC to get an upper endpoint number.. The Teensy then would Save this number permanently in itself to to be used as the upper limit of the analog axis..
I know this can be done in the normal memory so it will be retained as long as the power is NOT turned off to the Teensy but is there any way to Permanently save it for access after a Power Cycle.
Thank you,
