If I call set_arm_clock() with certain frequencies the clock is not set to the right value. I use the following program:
The while loop needs 4 cycles per loop and I measure its frequency with a counter.
If I call set_arm_clock(120000000) the cpu frequency changes to 120MHz, so that works. If I call set_arm_clock(24000000) the frequency is changed to approximately 30MHz (I think other users observed this already). If I call set_arm_clock(144000000) the frequency changes to 120MHz.
If I first call set_arm_clock(120000000); and thereafter set_arm_clock(24000000); the second call now changes the clock frequency to 24MHz as wanted. This trick also works with 144MHz: First set to 120MHz, then to 144MHz and the frequency changes to 144MHz.
I am currently looking at the source code of set_arm_clock(), but the function is quite complicated.
Any ideas what goes wrong in set_arm_clock(24000000) ?
extern "C" uint32_t set_arm_clock(uint32_t frequency);
int led = 13;
pinMode(led, OUTPUT);
while(!Serial) ;
Serial.println("teensy40setClockSpeedError1...") ;
Serial.printf("F_CPU_ACTUAL=%u",F_CPU_ACTUAL);
//set_arm_clock(120000000);
while(1){
CORE_PIN13_PORTSET = CORE_PIN13_BITMASK;
CORE_PIN13_PORTCLEAR = CORE_PIN13_BITMASK;
void loop(){
