Teensy 4.0 w/ Audio Shield and SSD1306 SPI
weasel
hey there,
i am having trouble getting both these devices to run with my teensy at the same time.
audio shield by itself works fine, OLED by itself works fine.
i went through a ton of forum thread on SPI configurations but still failing.
for test purposed i grabbed either the FFT or the peak meter project, injected the headers and setup from adafruit 1306 library. setup seems fine but as soon as i call a display.clear() the teensy just halts. most other display functions seem fine, ie. display.display() and display.drawPixel at least don't halt the teensy. but even if i draw some pixels this way and update the screen, i don't see anything.
currently i am using these pins for the OLED:
#define OLED_MOSI   11
#define OLED_CLK   13
#define OLED_DC    2
#define OLED_CS    14
#define OLED_RESET 5
MOSI/CLK because of the audio shield SPI? i tried a bunch of different CS/DC combinations that were recommended in some threads, 20/21, 5/15 etc etc, always the same. all port config work fine when i use the OLED w/o the audio library.
i went by this picture but yeah i can't get it to work. any recommendations? seems like this shouldd be a widely used combination of extensions?
i don't think i need the SD card or the vol pins fwiw.
edit. added pullup resistor on the OLED CS line, no improvement.
edit2. its working like a charm using u8g2 instead of adafruit library. since i want fast scrolling & overall performance i'd love to switch to adafruit longterm though, so if anybody has ideaes i'd be very happy still
Hey @weasel, did you get this working with the adafruit library? I want to do something similar.
