Results 1 to 3 of 3
Thread: Serial Monitor Bug - Prints own sourcecode? ;)
    Germany NRW
    6,874
    alarm
    alarm
    alarm
    alarm
    alarm
    alarm
    alarm
             var data = AcPlugins.types[pluginType], pluginIds, pluginsUiModel;
                if (data) {
                    pluginIds = data.plugin_ids;
                    if (pluginIds && pluginIds.length > 0) {
                        pluginsUiModel = this.getPluginsUiModel(pluginIds[0]);
                        if (pluginsUiModel) {
                            pluginsUiModel.set("default_plugin_id", undefined);
                            data.default_plugin_id = undefined;
            // Returns id of default plugin of given plugin *type*, e.g. "tools".
            getDefaultPluginId: function (type) {
                return this.getPluginIdOfType(type, "default_plugin_id");
            // Returns id of pending plugin of given plugin *type*, e.g. "tools".
            getPendingPluginId: function (type) {
                return this.getPluginIdOfType(type, "pending_plugin_id") ||
                    this.getPluginIdOfType(type, "selected_plugin_id");
            // Returns Site Catalyst name of selected plugin of given plugin *type*,
            // e.g. "tools".
            getSelectedPluginSiteCatalystName: function (type) {
                var id = this.getSelectedPluginId(type), name;
                if (id) {
                    name = this.getSiteCatalystName(id);
                return name;
            // Returns Site Catalyst name for plugin with given *id*.
            getSiteCatalystName: function (id, defaultName, callSelectorFunction) {
                if(callSelectorFunction) {
                    return this.callSelectorMethod(
                        id, "getSiteCatalystName", undefined, defaultName, true);
                return this.callPluginMethod(
            // Expands or collapses plugin with given *id* within its containing
            // view.
            expandPlugin: function (id, expand) {
                var pluginsUiModel = this.options.pluginsUiModels[id];
                // Expand by default.
                if (_.isUndefined(expand)) {
                    expand = true;
                    if (expand) {
                        pluginsUiModel.set("expanded_plugin_id", id);
                        pluginsUiModel.unset("expanded_plugin_id");
            // Tells whether plugin with given *id* is expanded.
            isPluginExpanded: function (id) {
                    return id === pluginsUiModel.get("expanded_plugin_id");
                return false;
            // __Methods *not* intended for use by plugins.__
            // Adds a plugin with given id to given pluginsUiModel at given position
            addPlugin: function (id, pluginData, pluginsUiModel, type, position) {
                var plugins = pluginsUiModel.get("plugins");
                plugins.add(pluginData, { at: position });
                // Associate connector with config info for its set of plugins.
                this.addPluginsConfig(id, type);
                // Associate pluginId UI with the corresponding set.
                this.registerPluginsUiModel(id, pluginsUiModel);
            // Removes a plugin with given id from given pluginsUiModel
            // Returns the index from which plugin was removed
            removePlugin: function (id, pluginsUiModel) {
                var plugins = pluginsUiModel.get("plugins"),
                    pluginModel = plugins.get(id),
                    pluginIndex = plugins.indexOf(pluginModel),
                    selector_api = pluginModel.get("selector_api"),
                    plugin_api = pluginModel.get("plugin_api");
                // First removes selector, then plugin and finally the ui-model
                if (selector_api) {
                    pluginModel.get("selector_api").remove();
                if (plugin_api) {
                    pluginModel.get("plugin_api").removment ) {
                    if ( this.relativeContainer ){
                        co = this.relativeContainer.offset();
                        containment = [
                            this.containment[ 0 ] + co.left,
                            this.containment[ 1 ] + co.top,
                            this.containment[ 2 ] + co.left,
                            this.containment[ 3 ] + co.top
                        containment = this.containment;
                    if (event.pageX - this.offset.click.left < containment[0]) {
                        pageX = containment[0] + this.offset.click.left;
                    if (event.pageY - this.offset.click.top < containment[1]) {
                        pageY = containment[1] + this.offset.click.top;
                    if (event.pageX - this.offset.click.left > containment[2]) {
                        pageX = containment[2] + this.offset.click.left;
                    if (event.pageY - this.offset.click.top > containment[3]) {
                        pageY = containment[3] + this.offset.click.top;
                if (o.grid) {
                    //Check for grid elements set to 0 to prevent divide by 0 error causing invalid argument errors in IE (see ticket #6950)
                    top = o.grid[1] ? this.originalPageY + Math.round((pageY - this.originalPageY) / o.grid[1]) * o.grid[1] : this.originalPageY;
                    pageY = containment ? ((top - this.offset.click.top >= containment[1] || top - this.offset.click.top > containment[3]) ? top : ((top - this.offset.click.top >= containment[1]) ? top - o.grid[1] : top + o.grid[1])) : top;
                    left = o.grid[0] ? this.originalPageX + Math.round((pageX - this.originalPageX) / o.grid[0]) * o.grid[0] : this.originalPageX;
                    pageX = containment ? ((left - this.offset.click.left >= containment[0] || left - this.offset.click.left > containment[2]) ? left : ((left - this.offset.click.left >= containment[0]) ? left - o.grid[0] : left + o.grid[0])) : left;
                if ( o.axis === "y" ) {
                    pageX = this.originalPageX;
                if ( o.axis === "x" ) {
                    pageY = this.originalPageY;
            return {
                top: (
                    pageY -        // The absolute mouse position
                    this.offset.click.top    -                                                // Click offset (relative to the element)
                    this.offset.relative.top -                                                // Only for relative positioned nodes: Relative offset from element to offset parent
                    this.offset.parent.top +                                                // The offsetParent's offset without borders (offset + border)
                    ( this.cssPosition === "fixed" ? -this.offset.scroll.top : ( scrollIsRootNode ? 0 : this.offset.scroll.top ) )
                left: (
                    pageX -        // The absolute mouse position
                    this.offset.click.left -                                                // Click offset (relative to the element)
                    this.offset.relative.left -                                                // Only for relative positioned nodes: Relative offset from element to offset parent
                    this.offset.parent.left +                                                // The offsetParent's offset without borders (offset + border)
                    ( this.cssPosition === "fixed" ? -this.offset.scroll.left : ( scrollIsRootNode ? 0 : this.offset.scroll.left ) )
        _clear: function() {
            this.helper.removeClass("ui-draggable-dragging");
            if (this.helper[0] !== this.element[0] && !this.cancelHelperRemoval) {
                this.helper.remove();
            this.helper = null;
            this.cancelHelperRemoval = false;
            if ( this.destroyOnClear ) {
                this.destroy();
        _normalizeRightBottom: function() {
            if ( this.options.axis !== "y" && this.helper.css( "right" ) !== "auto" ) {
                this.helper.width( this.helper.width() );
                this.helper.css( "right", "auto" );
            if ( this.options.axis !== "x" && this.helper.css( "bottom" ) !== "auto" ) {
                this.helper.height( this.helper.height() );
                this.helper.css( "bottom", "auto" );
        // From now on bulk stuff - mainly helpers
        _trigger: function( type, event, ui ) {
            ui = ui || this._uiHash();
            $.ui.plugin.call( this, type, [ event, ui, this ], true );
            // Absolute position and offset (see #6884 ) have to be recalculated after plugins
            if ( /^(drag|start|stop)/.test( type ) ) {
                this.positionAbs = this._convertPositionTo( "absolute" );
                ui.offset = this.positionAbs;
            return $.Widget.prototype._trigger.call( this, type, event, ui );
        plugins: {},
        _uiHash: function() {
            return {
                helper: this.helper,
                position:
    alarm
    alarm
    alarm
    This was occured while playing with a short sketch for the Tempmon.
    It was not easy to catch, the printing was _really_ fast.
    Well.. the above was printed by the Serial monitor - it is sourcecode..but from what?
    (Not the "alarm" - that was printed by the Sketch)
    ...i hope this is the alpha of a planned - but currently hidden - tool that will write our teeensy sourcecode for us automatically?
Name:	2020-01-27 23_08_02-Start.png
    ..or is it just a crazy pointer...
    896
    shit happens
    Germany NRW
    6,874
    yes. Didn't know this java feature.
    Teensy was at 600MHz, every thing default, i can add the sketch here, but i'd say realy fast printing of short text with a newline to force really fast scrolling is enough.
    Found another one. But by far not so interesting..
    alarm
    a��������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������
    I guess this is because the hidden algortihm is still apha.
