paulskirk53
Hello all, this is my first post on the PJRC forum. I am new to Teensy, having just acquired a Teensy 3.6. I have some experience of programming Arduino Mega 2560 and until now I have used the Arduino IDE. However, I have installed Sublime text 3 and some packages to enhance it and would like to use it to generate my Teensy code and compile and upload.
I have read this thread post #90
https://forum.pjrc.com/threads/3839...DE-replacement?p=193211&viewfull=1#post193211
and it was helpful to understand the context. I also went to defragster on github:
https://github.com/Defragster/Tset
and read there about using Tset
and also here to use tycmd https://github.com/Koromix/tytools
So with my limited knowledge of this, I have installed the arduino ide and teensyduino, installed Tset and tycmd. I have Run Tset.cmd and edited Tset.cmd1 to have folder paths to my local system as follows.
rem Edit these paths:
set arduino=c:\arduino
set TyTools=C:\Arduino\tytools-master
set libs=C:\Arduino\libraries
set tools=C:\Tset-master
Sublime text is installed here: C:\Program Files\Sublime Text 3
In sublime text, i have added this (from defragster github) in tools>build system > new build system:
>> FORMAT CODE when using installed package :: SublimeAStyleFormatter
Ctrl+ Alt+ f
>> USER BUILD FILE for Teensy :: Teensy.sublime-build
>> Ctrl+ Shift+ B to select below and F7 to repeat last build command
"%AppData%\Sublime Text 3\Packages\User\Teensy.sublime-build"
"shell_cmd": ".\\Compile.cmd 1",
"file_regex": "^(..[^:]*)[0-9]+):?([0-9]+)?:? (.*)$",
"working_dir": "${file_path}",
"selector": "source.c, source.c++",
"variants":
"name": "Clean",
"shell_cmd": ".\\Compile.cmd 2",
"name": "New Sketch",
"shell_cmd": "start T:\\Programs\\TSet\\open_new.cmd",
"name": "Verify",
"shell_cmd": ".\\Compile.cmd 0",
"name": "Tools Set",
"shell_cmd": "start T:\\Programs\\TSet\\TSet.cmd",
But I am not sure how to modify the above code to make it fit with my installed folders. Please could anyone advise me how to modify the above code to fit with my directories?
Also I did not quite understand this in defragster's github readme :
"Run Tset.cmd ( must include extention .cmd )" i have done this, and it goes on to say
"from the Sketch folder where the INO is stored for IDE usage. It can run from within your IDE or from CMD line or Explorer window." - what does it mean "where the INO is stored" - is this the arduino files directory??
So any further explanation would be greatly appreciated.
Also any help with ensuring I have the key components installed in the correct places would be helpful.
Many thanks for your help,
Paul
Ctrl+ Alt+ f
"variants":
"name": "Clean",
"name": "Verify",
Paul
