Results 1 to 18 of 18
Thread: Unable to wake Teensy LC using Snooze
    Dec 2019
    19
    I'm having issues waking my teensy LC using the sleep_all_wakeups. I commented out all but the digital wakeups and added a serial output at the start of setup to make sure that the current code is running on the board. I manually connect pin 21 or 22 to the 3.3v pin. When I boot it, I manually unplug and replug that wire in order to create the rising edge. No luck. I have no idea what to do from here.
     This shows all the wakeups for sleep
     Expect IDD of  around 1.2mA (Teensy 3.x)
     and IDD of around 900uA for (Teensy LC).
     Sleep is the most flexable and any
     interrupt can wake the processor.
     Touch interface does not work in sleep
     mode.
    #include <Snooze.h>
    // Load drivers
    SnoozeDigital digital;
    SnoozeCompare compare;
    SnoozeTimer timer;
    SnoozeAlarm  alarm;
    // configures the lc's 5v data buffer (OUTPUT, LOW) for low power
    Snoozelc5vBuffer  lc5vBuffer;
     Teensy 3.6/LC can't use Timer Driver with either Touch or
     Compare Drivers and Touch can't be used with Compare.
     Teensy 3.x/LC touch interface does not work with sleep.
     Teensy LC does not have a rtc so Alarm driver can't be
     used as of yet.
     Teensy 3.2 can use any Core Drivers together.
    #if defined(__MK66FX1M0__)
    SnoozeBlock config_teensy36(digital, alarm, compare);
    #elif defined(__MK64FX512__)
    SnoozeBlock config_teensy35(digital, timer, compare);
    #elif defined(__MK20DX256__)
    SnoozeBlock config_teensy32(digital, timer, compare);
    #elif defined(__MK20DX128__)
    SnoozeBlock config_teensy30(digital, timer, compare);
    #elif defined(__MKL26Z64__)
    SnoozeBlock config_teensyLC(digital, timer, lc5vBuffer);
        pinMode(LED_BUILTIN, OUTPUT);
        while(!Serial){}
        Serial.println("Started v1.0.8");
        delay(10000);
         Define digital pins for waking the teensy up. This
         combines pinMode and attachInterrupt in one function.
         Teensy 3.x
         Digtal pins: all pins
         Teensy LC
         Digtal pins: all interrupt able pins
        digital.pinMode(21, INPUT_PULLUP, RISING);//pin, mode, type
        digital.pinMode(22, INPUT_PULLUP, RISING);//pin, mode, type
         Teensy 3.x only currently.
         Set RTC alarm wake up in (hours, minutes, seconds).
        //alarm.setRtcTimer(0, 0, 10);// hour, min, sec
         Set Low Power Timer wake up in milliseconds.
        //timer.setTimer(5000);// milliseconds
        In sleep the Compare module works by setting the
        internal 6 bit DAC to a volatge threshold and monitors
        the pin volatge for a voltage crossing. The internal
        DAC uses a 64 tap resistor ladder network supplied by
        VOUT33 at 0.0515625v per tap (VOUT33/64). Thus the
        possible threshold voltages are 0.0515625*(0-64). Only
        one compare pin can be used at a time.
        parameter "type": LOW & FALLING are the same and have no effect.
        parameter "type": HIGH & RISING are the same and have no effect.
        Teensy 3.x
        Compare pins: 11,9,4
        Teensy LC
        Compare pins: 11
        // trigger at threshold values greater than 1.65v
        //compare.pinMode(11, HIGH, 1.65);//pin, type, threshold(v)
        // trigger at threshold values less than 1.65v
        //compare.pinMode(11, LOW, 1.65);//pin, type, threshold(v)
        int who;
         feed the sleep function its wakeup parameters. Then go
         to deepSleep.
        who = Snooze.sleep( config_teensy36 );// return module that woke processor
        who = Snooze.sleep( config_teensy35 );// return module that woke processor
        who = Snooze.sleep( config_teensy32 );// return module that woke processor
        who = Snooze.sleep( config_teensy30 );// return module that woke processor
        who = Snooze.sleep( config_teensyLC );// return module that woke processor
        if (who == 21) { // pin wakeup source is its pin value
            while(true) {
                delay(200);
                delay(200);
        if (who == 22) { // pin wakeup source is its pin value
            while(true) {
                delay(200);
                delay(200);
        if (who == 34) { // compare wakeup value
            for (int i = 0; i < 3; i++) {
                delay(200);
                delay(200);
        if (who == 35) { // rtc wakeup value
            for (int i = 0; i < 4; i++) {
                delay(200);
                delay(200);
        if (who == 36) { // lptmr wakeup value
            for (int i = 0; i < 5; i++) {
                delay(200);
                delay(200);
    Nov 2017
    Belgium
    215
    The internal pullup resistors are enabled so you need to connect pin 21 or 22 to GND.
    Unplugging the wire will then create a rising edge.
    Dec 2019
    19
    Quote Originally Posted by neurofun View Post
    I connected 21 and 22 to GND(1 pin further from the two) and unplugging to create the rising edge. The on board still did not blink when this happen. It does blink when it boots since I added that to the code.
    Nov 2017
    Belgium
    215
    Tested the code and indeed it does not work. Upon further investigation I found 2 issues.
    First:
    The following does not activate the internal pullup resistors.
    You need to add the following to setup() in order to activate the internal pullups.
        pinMode(21, INPUT_PULLUP);
        pinMode(22, INPUT_PULLUP);
    Secondly:
    Using arduino 1.8.9
    Compiled with TD1.49 does not work.
    Compiled with TD1.48 does work.
    Apparently there was a change in the directory structure of the Snooze lib going from TD1.48 to TD1.49, maybe something got messed up.
    Dec 2019
    19
    First:
    Sadly this did not fix it either.
    Secondly:
    Using arduino 1.8.9
    Where would I get an old version of TD? I am using 1.49
    12,673
    Links to prior copies like for TD 1.48 are: https://www.pjrc.com/teensy/td_148/
    Nov 2017
    Belgium
    215
    Quote Originally Posted by ErkelByte View Post
    This was only meant to enable the pullup resistors, not as a fix for the Snooze lib.
    See @defragster's previous post.
    You must completely remove your current TD1.49 install of the Snooze lib before installing TD1.48.
    If you don't, the TD1.48 installer won't be able to handle the change in the directory structure of the Snooze lib and you will end up with a mix of both Snooze libs and it still won't work!
    Nov 2017
    Belgium
    215
    It might actually be a better idea to download v6.3.3 of the Snooze lib and install it in the user library folder instead of downgrading TeensyDuino.
    Snooze lib v6.3.3 -> https://github.com/duff2013/Snooze/t...81e164ca123e3a
    Dec 2019
    19
    The 1.48 downgrade worked! I'll look into 1.50 when that comes out as like neurofun said that is a better idea. However I just needed to check that it works as I have to finish the rest of the project until I put it into use.
    Senior Member duff's Avatar
    Las Vegas
    1,023
    I'm going to work on this today, been out with the death flu for the last two weeks but starting to feel like half of myself again.
    Nov 2017
    Belgium
    215
    Quote Originally Posted by duff View Post
    To recap the problems found so far with v6.3.4.
    Tested with TLC, T3.2 & T3.6.
    The following does not work:
    -enabling the pullup resistors via SnoozeDigital.pinMode()
    -wake from digital pin
    -wake from timer
    Wish you a speedy recovery.
    Aug 2020
    9
    The data:
    • Teensy v3.5
    • Snooze library v6.3.8
    When the processor is hibernating, it does not wake up using a digital pin. From a STM32 board I signal pin 21 of the teensy so that it wakes up but it is not working.
    The code in the Teensy is:
      SnoozeDigital snooze_digital;
      SnoozeBlock config_teensy35(snooze_digital);
      // more code
      snooze_digital.pinMode(21, INPUT_PULLUP, FALLING);//pin, mode, type
      // more code
      int who = Snooze.hibernate( config_teensy35 );
      if (who == 21) {
       // magic code
    The code in STM32 board (I am using ChibiOS):
      palSetPadMode(GPIOG, 11, PAL_MODE_OUTPUT_PUSHPULL);
      palWritePad(GPIOG, 11, PAL_LOW);
      // more code
      chThdSleepMilliseconds(10);
      palWritePad(GPIOG, 11, PAL_HIGH);
    What am I doing wrong?
    Thank you
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    330
    Also struggling to get Snooze to work on a Teensy LC [while Teensy 3.2 works fine for a digital pin wake up].
    Environment:
    My setup:
Name:	TeensyLC Snooze.jpg
    The output on the serial monitor when I plug in the Teensy LC:
Name:	TeensyLC Snooze serial monitor.png
    I checked the voltage on the expected pulled-up pin 7: 3V3.
    Pushing the button for >3 secs does not wake up the Teensy LC.
    Running the exact same code on a Teensy 3.2 works OK: it wakes up and goes to sleep after 7 secs.
    Deep-sleep current measured on the T3.2 [USB cable removed, line 44 // while (!usb); uncommented and powered externally with 5V on the Vin pin]: 271 uA - nice! Alive current is 38 mA.
    I looked into the Snooze code but did not see any obvious mistake [mind you, my coding skills are mediocre...]
    Your support to get the Snooze library working on a Teensy LC would definitely be appreciated.
    Regards,
    Paul
    Las Vegas
    1,023
    @PaulS I'll take a look at that sketch with T-LC tonight. It worked when I was testing all the different Teensy's, does just a simple pin wakeup work?
    Apr 2015
    Netherlands
    330
    Hi Duff, thanks for looking into this. No need to hurry though.
    I'm not sure I correctly understand you when you ask "does just a simple pin wakeup work?". The sketch I mentioned above does only wake-up from a pin?
    Paul
    2,593
    OK, I ran deepsleep/button_hold_wakeup sketch on my LC. As noted in post #13 sketch did not come out of deepsleep when pin 7 was grounded. I don't pretend to understand much of the LC snooze logic, but assuming it's using LLS and the LLWU mask bits, I note that pin 7 (PTD2) is not listed as a wakeup pin in table 3-15!?!
                 LLWU_P5 PTB0    16
                 LLWU_P6 PTC1    22
                 LLWU_P7 PTC3     9
                 LLWU_P8 PTC4    10
                 LLWU_P9 PTC5    13
                 LLWU_P10 PTC6   11
                 LLWU_P14 PTD4    6
                 LLWU_P15 PTD6   21
    So I changed bounce pin from 7 to 6, and LC sketch worked. With no USB deepsleep measured 188.6 ua. Hibernate example with pin 6, 4.1 ua.
    Comments in other snooze examples say
        Teensy LC
        Digtal pins: 6,9,10,11,13,16,21,22
    Las Vegas
    1,023
    Yep, your right, (PTD2) pin 7 is not a wake up pin while in deepSleep or hibernate. I'll update the example to reflect this, thanks!
    Apr 2015
    Netherlands
    330
    Thanks Manitou and Duff!
    LC waking up on grounding pin 6 is working fine with the updated sketch https://github.com/duff2013/Snooze/b...old_wakeup.ino.
    Measured deepsleep current [USB cable removed, line 44 // while (!usb); uncommented and powered externally with 5V on the Vin pin]: 191 uA. Alive current is 12.7 mA.
    Paul
