Results 1 to 6 of 6
Thread: Audio Recorder, Can't Hear Playback
    This is my very first test with the Teensy Audio Library so probably just make a basic error.
    Simply, can't hear any playback from the recording in the Recorder Example. I have tested audio both out of the headphones and the Line Out with a 0.5W speaker.
    All the buttons seem to be working fine (Stop, Play, Record). I checked the SD card and the file RECORD.RAW was written. So it must be something with my mic or output?
    Here is the circuit if it helps:
    Thanks x100
    Germany NRW
    6,541
    You can not connect a speaker to lineout.
    Linout is to connect an ampilifier.
    The easiest is probably to connect active PC-Speakers.
    Then, try the other examples and first test if you hear something.
    Try headphones, too.
    Ah yes okay I will connect the line to some amplification and try again.
    I tried headphones. Any reason why I could not hear anything through headphones? Is there a way in the code to specify line-out versus headphones? Or is it always outputting to both?
    thanks.
    Germany NRW
    6,541
    If the examples do not work, there is something wrong with your hardware. Check the soldering and such things..
    Use the guitar example.
    1,244
    The connections to the Teensy's power and ground look to me like you have just stuck the jumper pins in the holes without any solder.
    There also appear to be other connections to the boards which are done like this.
    Connections to those pins on the boards MUST be soldered.
    Pete
    It's working well now. Added a 2.5W amplifier to the line out. And most importantly, hooked up an AGC microphone module, which eliminated all the noise.
