I got sleep working thank you to the awesome people on this forum. However when it wakes up from a DS3231 RTC it refuses to print to the Serial monitor. The Serial Monitor rapidly flips between connected and disconnected. Please let me know what I'm doing wrong while trying to print.
This shows all the wakeups for sleep
Expect IDD of around 1.2mA (Teensy 3.x)
and IDD of around 900uA for (Teensy LC).
Sleep is the most flexable and any
interrupt can wake the processor.
Touch interface does not work in sleep
mode.
#include <Snooze.h>
// Load drivers
SnoozeDigital digital;
SnoozeCompare compare;
SnoozeTimer timer;
SnoozeAlarm alarm;
// configures the lc's 5v data buffer (OUTPUT, LOW) for low power
Snoozelc5vBuffer lc5vBuffer;
Teensy 3.6/LC can't use Timer Driver with either Touch or
Compare Drivers and Touch can't be used with Compare.
Teensy 3.x/LC touch interface does not work with sleep.
Teensy LC does not have a rtc so Alarm driver can't be
used as of yet.
Teensy 3.2 can use any Core Drivers together.
SnoozeBlock config_teensyLC(digital, lc5vBuffer);
#include <DS3232RTC.h>
DS3232RTC RTC(false);
int idx = 0;
pinMode(LED_BUILTIN, OUTPUT);
while(!Serial){}
delay(5000);
Serial.println("Started v1.0.12");
RTC.begin();
setSyncProvider(RTC.get); // the function to get the time from the RTC
if(timeStatus() != timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
Serial.print(hour());
Serial.print(':');
Serial.print(minute());
Serial.print(':');
Serial.println(second());
delay(10000);
Define digital pins for waking the teensy up. This
combines pinMode and attachInterrupt in one function.
Teensy 3.x
Digtal pins: all pins
Teensy LC
Digtal pins: all interrupt able pins
pinMode(21, INPUT_PULLUP);
pinMode(22, INPUT_PULLUP);
digital.pinMode(21, INPUT_PULLUP, RISING);//pin, mode, type
digital.pinMode(22, INPUT_PULLUP, RISING);//pin, mode, type
// setup alarm
RTC.alarmInterrupt(ALARM_1, true);
RTC.setAlarm(ALM1_MATCH_SECONDS, ((second() + 40) % 60), 0, 0, 1);
RTC.squareWave(SQWAVE_1_HZ);
// clear the alarm flag
RTC.alarm(ALARM_1);
int who = 0; // what woke us up
feed the sleep function its wakeup parameters. Then go
to deepSleep.
who = Snooze.deepSleep( config_teensyLC );// return module that woke processor
// wait for serial monitor
elapsedMillis time = 0;
while (!Serial && time < 1000) {
Serial.write(0x00);// print out a bunch of NULLS to serial monitor
digitalWriteFast(LED_BUILTIN, HIGH);
delay(30);
digitalWriteFast(LED_BUILTIN, LOW);
delay(30);
// normal delay for Arduino Serial Monitor
delay(200);
// print who woke the teensy up, i.e. timer || digital
Serial.printf("Timer Driver number indicator: %i | index: %i\n", who, idx);
idx++;
