Hi there.
I'm using a Teensy 4.0 for a robotics project I'm working on and I'm wondering if it's possible to reflash the device using a Raspberry Pi which has it's UART connected to Serial1 on the Teensy? I'd like to be able to update the firmware as part of the release cycle on the Raspberry Pi. Failing that, given that the Pi and the Teensy are sharing the same 5V source, would that cause any issues with VUSB if I were to connect the Teensy to the Pi over USB (I'd rather avoid this if possible).
Thanks.
Thanks.
